Measuring my ride height???
Old 06-29-2004, 03:37 PM
95DXPhiladeph's Avatar
Default Measuring my ride height???
Well my suspensions all out of whack... one sides a good 1/4" higher than the other side...
I'm putting it up on the lift tomorrow to get it straightened out... I'm wondering once I pop off the wheels where can I measure to set both sides the same?
from the center of the rotor to the top of the springs? what position is gonna be the same on both sides once i adjust my coilovers?
thanks!
Old 06-29-2004, 04:08 PM
ej1 pilot's Avatar
Default Re: Measuring my ride height??? (95DXPhiladeph)
measure the wheel gap while its on the ground, or form the ground to the rear 1/4
Old 06-30-2004, 05:54 AM
Default Re: Measuring my ride height??? (Art In Motion)
then how do i know how many turns to adjust the coilover once it's off the ground?
Old 06-30-2004, 05:58 AM
SolObsession's Avatar
I usually count the number of threads showing under the spring on the sleeve.
Old 06-30-2004, 06:04 AM
Risky Business
BauleyCivic's Avatar
It would be hard to measure the ride height when the car is on a lift. Keep the car on the ground, measure the rim to fender distance on all four wheels, then make the necessary adjustments. Thats what I do
Old 06-30-2004, 06:28 AM
nahledge 7's Avatar
if uhave adjustale coil sleeves, then u can just measure how low u want it from the top of the sleeve to where u lock it.
moonchies
03-21-2018 09:39 PM
bsmith100
Suspension & Brakes
06-16-2009 09:19 PM
ComCool
Suspension & Brakes
06-07-2006 10:13 AM
JDM-EJ1
02-17-2004 12:03 PM
py1188
05-30-2003 08:14 AM
Quick Reply: Measuring my ride height???
