measurement....
Old 03-15-2007, 06:44 PM
Lil_Wyte's Avatar
Default measurement....
can someone please measure the width of the car from fender to fender....tip right at the headlights and the other end by the windshield....for a 92-95 civic hatch
thanks....its just to see where my alignment is out...nothing is lining up
Old 03-15-2007, 06:53 PM
93eg2james's Avatar
Default Re: measurement.... (Lil_Wyte)
Have it aligned. When you have it alligned they set the steering wheel at dead center, then from there they adjust you camber/caster/toe. Its not expensive, and it's a good idea. Its much harder to do something like this without a machine.
At school, the alignment machine pretty much does it for you. After you put the steering wheel at dead center, and attach some laser plates to the wheels, the machine tell you exactly what values you're at, and what to do to adjust them. After you do the adjustment it reads the new setting and tells you if anything is off. It completely idiot proff.
Old 03-16-2007, 03:40 AM
Lil_Wyte's Avatar
Default Re: measurement.... (93eg2james)
anyone else please?
Old 03-16-2007, 07:27 AM
93eg2james's Avatar
Well, if you'd like to get the measurments, go outside with a tape measure and do it. If you try to do an alignment like this you're destin for failure. Good Luck
swizz977
15
01-29-2012 04:20 PM
DJLikwid
Suspension & Brakes
12-24-2007 09:19 AM
Nothing.Special
Suspension & Brakes
05-23-2005 08:08 AM
ultimatehonda
07-08-2003 03:28 AM
XEventHorizonX
02-19-2003 06:49 PM
Quick Reply: measurement....
