Max RIM SIZE?
Max RIM SIZE?
what is the largest rim i could fit on my 97 del sol
could i see some 16X8 wheels on civics or del sol would be better pictures guys
like XXR 513, or (ROTA RB) wheels old school Wide lip rims
+4 offset on 8 inch wide and +20 offset on 7 inch wide
could i fit 8s or not?
Re: Max RIM SIZE?
no i only roll 16s i want to know if any thing will hit if i run 16X8 or if ill be good
clearance wise that what i wana know
Re: Max RIM SIZE?
with a +40mm offset you will probably rub the inside of the wheelwell on really right U-turns. avoid tight U-turns and it'll be fine... well, you may need to roll the fenders if you're lowered.
Another thing is, if you're lowered (this applies to all wheel sizes, unless your overall wheel/tire size is smaller than stock), inside the top of the wheelwell is a wide metal tab sticking down. It will cut chunks out of your tires if you don't bend the tab to the side and out of the way with a hammer.
Re: Max RIM SIZE?
8 is gonna be way too wide. my 7's are just right. not that 8's WON't work, but I definitly wouldn't risk that because it would be REALLY close, and if your lowered probably wont work at all.
and definitely never ever go bigger than 16 on a del sol. 15's with 205/50's are perfect on mine, even better if it was lowered.
Re: Max RIM SIZE?
ah screw you guys!
i have 17's on my civic. came with the car, and i like it.
i think small rims like 15's are STR8 OUT RICER!
not to mention the fact that they look UGLY AS F*** and gay as hell
but its my $.02
if you hate it, oh well. suck it up and live on. life is a b***h.
but its my $.02
Re: Max RIM SIZE?
Re: Max RIM SIZE?
yes there is. and i KNOW that i am going to be flamed by it. and i KNOW that ppl with think im an idiot and will hate me. but its my opinion. just like ppl think other stuff is ricer, some one else may have a different opinion
Re: Max RIM SIZE?
I used to have 17" rims and they looked pretty good and with my drop and front lip the rims didn't look too big really to me. However, the practicality of the 17" rim was non-existent. 205/40/17 tires don't provide enough sidewall to give a comfortable ride on aftermarket suspension, and make the rims more vulnerable to being bent when hitting a pothole. Also, the 17" tires are more expensive, the 17" wheels are more expensive, the wheels are usually heavier than smaller ones, and the rims are usually harder to fit in the wheel wells without modifications such as fender rolling.
If you want to deal with all of those cons, more power to you.
The only thing I really hate about the big wheels is when people claim they care about performance, but then go buy a heavy set of 17" rims and then choose their rims solely on looks, without taking into account the practicality of the rim.
Re: Max RIM SIZE?
ah screw you guys!
but its my $.02
but its my $.02
I honestly think 15's are the best size to go with, i had 19's on my 96 coupe when i first bought it, ride was terrible. They rubbed on stock suspension. i had enough and went to 15's.
Re: Max RIM SIZE?
you are the idiot. in fact your such an idiot you should crash your honda into a tree and die. since you are too much of a ***** to make another user name to talk ****.
go suck you 2 dads d***
Re: Max RIM SIZE?
wow. here is some idiot that probably has a nice amount of posts here but was too much of a ***** to post it with his own, main username.
Re: Max RIM SIZE?
What I think determines rice, whether it be any rim size (except 18"+, those are ALL ricey when they're on a 92-00 Civic) is the actual style of the rim. There are plenty of ricey 15", 16" and 17" rims out there, and plenty of good looking ones.
but i looked at all the details and i decided to keep my 17's since i will not drop my car 2 inches from the floor like i see many civics now a days.
just about 1.5 - 2.5 inches would be good
