master cylinder ?
master cylinder ?
i just picked up a 15/16 master cylinder and booster.. took everything out of my car and installed the boost and MC, but when i went to put the lines back in the one closest to the front was fine, but the one by the fire wall used a larger fitting than my stock 95 dx. anyone know what MC that might be? i figure knowing that would help me get the right sized fitting.
Re: master cylinder ? (Zer0DazE)
What car did you new MC come out of? More than likely, you have an MC from an ABS model which means you will have to flare the line closest to the firewall to make it fit unless you have ABS on your 94EX.
Re: master cylinder ? (Kalokohan)
from what i understand it came out of a civic, but i didnt take it out of the car.
i assumed i was going to have to reflare it, i was more or less wondering what size end i had to put on it. i figured perhaps someone else had run into a similar issue and had to order a fitting. what car do i need to tell the parts guy i need it from?
thanks
thanks
hammeredgsr
04-01-2010 04:43 PM
