maplights
i been meaning to put maplights in my car. but the thing is i have a 95 ex w/ a sunroof. i wanted to put integra maplights exactly where its located in integras (between the sun visors) but the fuckin sunroof motor is right there. anyone with a 92-95 si/ex conquer this problem? is there enough room between the headliner and sunroof motor to make this work?
my 96 ex coupe has a maplight right between the visors - doesnt interfear with the motor.
Try using that as a starter? |
I bought a JDM optional rear view mirrior for my Si that has maplights built in. You could probably find a similar mirror from a newer car and wire it up. Most window mounted mirrors all mount the same way. just an Idea.
Re: maplights (Hugh G. Rection)
I took a mirror from a chrysler car that had map lights built in and wired it up to my sol, search my created topics if your interested. https://honda-tech.com/forums/images/smilies/emthup.gif
Re: maplights (nocturnaldragon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nocturnaldragon »</TD></TR><TR><TD CLASS="quote">I took a mirror from a chrysler car that had map lights built in and wired it up to my sol, search my created topics if your interested. https://honda-tech.com/forums/images/smilies/emthup.gif </TD></TR></TABLE>
I did the same thing. Looks like stock and works like stock. |
Re: (Vero)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Vero »</TD></TR><TR><TD CLASS="quote">my 96 ex coupe has a maplight right between the visors - doesnt interfear with the motor.
Try using that as a starter?</TD></TR></TABLE> pic? |
Re: (Hugh G. Rection)
The maplight only sticks up out of the headliner about a half an inch. So you should have enough room to mount it.
Re: (Jeremy D. Swain)
has anyone sucessfully done this though? im not about to cut a hole in my headliner to find out the maplight sticks up 2mm's too high into a moving gear
I've installed my Si maplight, but I also don't have a sunroof.
Maybe someone will actually have one, or you could just pop your headliner down, and measure the space that you would have. It would kinda suck though. |
Re: maplights (Ninety5Ex)
Yup, I wonder why I dident do it sooner. Everyones asks me if that came like that cause there friends dident have it or just assume its stock if there not familier with the sols
Re: maplights (ELUSIVESIR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ELUSIVESIR »</TD></TR><TR><TD CLASS="quote">Check this link out, it might help you out some.
http://www.jdmcivic.com/forums...21661</TD></TR></TABLE> pics no workie https://honda-tech.com/forums/images/smilies/emsad.gif |
bump for some pix https://honda-tech.com/forums/images/smilies/emthup.gif
