map sensor trouble in ohio
map sensor failed and fouled all of my plugs. anyone have one? 92 civic EX. was using iridium denso, on turbo motor, am I doing something wrong?
need....more....info
what is your setup? Engine? Turbo? ECU? Ae you FMIC? |
Re: (turbotime)
d16z6 greddy turbo kit, p28 ecu. if map sensor is bad will it foul my plugs?
Re: (sonicivic)
Have you pulled the plugs to look at them? You need to do that.
We were told by NGK to use BKR7E11 I think it was, I have it written down someplace. They cost about $2.00 each. We have an Apexi kit on the 92Si. If you check out http://www.turbod16.com there are post there about it. |
Re: (smithby)
I pulled the plugs and they were very black, with carbon build up
