Map sensor code 3 will not go away
92 Civic CX
jdm d15b w/ d16head
boosted w/ chipped ECU
Using EX engine harness
The motor that is in my hatch ran fine when it was previously in my coupe. All I did was remove the motor and drop it in the hatch. Since I did that the hatch has thrown a constant map sensor Code 3.
The code comes on right after I start the car and stays on.
I have:
Swapped map sensors - same result
Traced wires back to ECU - good continuity
Checked that wires are in right spots - good
Tried different vacuum source -same
Changed the bin on my ECU chip (using Crome) - same
Reset ECU - same
Thing is when I pulled out the old CX motor there was NO map sensor. Nowhere, not on the firewall or engine and the car ran fine (with stock motor). I am at my wits end trying to figure this out and am about to give up.
Any help would be appreciated.
Thanks
jdm d15b w/ d16head
I have:
Reset ECU - same
Thanks
Honda map sensors hate seeing boost. Did you recently up the boost? You need to upgrade to a 2 or 3 bar map sensor. Either that or cheap out and get a missing link, if youre running less than 10 lbs.
mr2turbo007
04-23-2012 06:22 PM
