Magnetic drain plug??
Re: Magnetic drain plug?? (CivilizedCiv)
it does get screwed on but there is a magnet that is at the end of the bolt and it attracts the metal pieces floating around in your fluids.
Re: Magnetic drain plug?? (dwnthehatch)
If you haven't had any internal work done (i.e. porting) then you're not going to see any metal bits.
[Modified by hybridreams, 10:37 AM 3/21/2002]
Re: Magnetic drain plug?? (hybridreams)
you can magnatize it for free guys. this is how you magnatize tools. works the same way. get an old speaker. the bottom end of the bolt. touch it to the magnet on the speaker and drag it around the magnet. magnatized. its probably not as powerful but it works for free.
[Modified by KAMiN, 7:53 AM 3/21/2002]
check out my install pics... http://www.deeperimage.com/forums/sh...=&threadid=520
i thought the transmission oil drain plug is magnetic ..
last time i change the oil .. lots of metal pieces was hanging on it ..
my frd told me it is normal since it is the car first gear oil change ...
There are metal bits EVERY time. Mostly a fine grit of metal powder, but there are certainly particles present.
Shawn
Re: Magnetic drain plug?? (Mike P.)
I wouldn't think you need a plug like this if oil filters actually work the way they're intended to work.
Shawn
vannak_5415
10-06-2008 05:34 PM
crxgator
29
07-17-2004 05:48 AM
