lug sutd help!!
lug sutd help!!
i have been on here for about an hour searching and cant find ne thing at all on this... i just need to change 2 studs in the back and one in the front and i have never done them.. please give me a heads up and some pics if avaliable
for a 94 civic with disk breaks all the way around!
Re: lug sutd help!! (lattimer2012)
You need to remove the hubs. I don't have any pics, but if you refer to a manual they will show you how to remove the hub. The rear hubs are bolted in (if memory serves me) and the fronts are pressed in. Once that is done you can simply press the stud out, or get a nice 3lb. hammer and one good whack will push them through.
Re: lug sutd help!! (RIZOBIZERT)
thanks i have had people around here tellin me that they have to be pressed out and in buy a machine shop but i didnt think so..
You should be able to hit them out with a hammer, when you install them try to hit the back of them to press them in a little bit.. THen when you tighten your lugs it should pull "press" it in the rest of the way.
koolkevin1107
12
11-11-2005 04:45 AM
JDM_ITR
09-11-2002 09:12 AM
