Lucas transmission fix - stops slip
Old 10-19-2009, 05:54 AM
lovelove's Avatar
Default Lucas transmission fix - stops slip
I was told from my cousin that you can put lucas transmission fix - stop slip in with the manual transmission fluid. It appears to me that the lucas fluids are a whole lot thicker than the regular castrol gtx 10W-30 that I am using. Is this safe? Its not that I am planning to put in my car, an EJ1.
Old 10-19-2009, 06:08 AM
RyanA's Avatar
Default Re: Lucas transmission fix - stops slip
Well, is your manual transmission slipping?
Old 10-19-2009, 06:16 AM
lovelove's Avatar
nope, my transmission isn't slipping at all.
Old 10-19-2009, 04:27 PM
RyanA's Avatar
Exactly. So why would you put a "pour in repair" fluid designed for an automatic trans in a manual? Just run Honda MTF, Pennzoil synchromesh, or GM Synchromesh. Honda manual transmissions don't like thicker fluid in them; the needle bearings and other tight areas tend to not get lubricated if you run a thicker fluid.
Old 10-19-2009, 05:06 PM
fastrxu's Avatar
^^^ dont mean to thread jack but
How much syncromesh do you put in the tranny? The same amount as if it were MTF?
Or do you do 50 50 or what?
Old 10-19-2009, 07:27 PM
RyanA's Avatar
You can run straight synchromesh or some people run it 50/50 synchromesh and honda mtf. Buy 3 quarts total fluid. About halfway through your 3rd, you'll have it full (on a B series)
prodjay10
Honda Civic (2001 - 2005)
08-13-2016 02:14 PM
Walter640
Honda CR-V & Element
02-02-2012 03:42 AM
racerxh00
07-23-2008 11:09 PM
sdr85
01-28-2008 07:57 PM
89D15CRXDX
10-18-2006 03:37 PM
Quick Reply: Lucas transmission fix - stops slip
