Lsvtec in 96 hatch breaks up in high rpm
Old 09-20-2011, 07:33 PM
203_EM2's Avatar
Default Lsvtec in 96 hatch breaks up in high rpm
Just finished my lsv setup in my hatch and when in high rpms the car breaks up sounds like crazy misfire. Rpm gauge goes bananas, jumps from 6k-8k then 0 repeatedly. At first we thought it was the coolant temp sensor bc it was throwing that code, but we figured out we forgot to splice and connect that :facepalm:. Used to only do it once in a while but now everytime it goes into vtec it breaks up. B16a2 head on b18b1 block chipped p28.
Old 09-21-2011, 09:41 PM
ssaechao04's Avatar
Default Re: Lsvtec in 96 hatch breaks up in high rpm
try replacing your igniter im pretty sure that will take care of your problem.
Old 09-22-2011, 12:31 AM
virgineg6's Avatar
New dizzy, wires, and spark plugs?
Old 09-22-2011, 12:56 AM
boostedteg909's Avatar
definitely a dizzy related issue
Old 09-22-2011, 06:29 AM
203_EM2's Avatar
It was the dizzy, new cap and rotor and now I'm ripping all the way to 8500. Thanks
Old 09-22-2011, 07:05 PM
rudebwoyEg's Avatar
my hatch does the same thing after after about 5.8- 6k rpm the tach goes krazy,
Old 10-01-2011, 02:51 PM
203_EM2's Avatar
ok so it wasnt the cap and rotor, car still does it no CEL anybody know what could be wrong?
Old 10-01-2011, 02:58 PM
Evoinboost's Avatar
wires and plugs
Old 10-01-2011, 03:19 PM
203_EM2's Avatar
brand new wires and plugs both NGK
Old 10-01-2011, 03:20 PM
92lxsleeper's Avatar
your gonna spin bearings revving that up past 7k
Old 10-01-2011, 03:29 PM
joeshmo's Avatar
Did you gap your plugs properly? How is your fuel system? Check fuel pressure.
Old 10-01-2011, 03:32 PM
GDD Black Reject
Mrevann's Avatar
check ur grounds.
Old 10-01-2011, 03:36 PM
203_EM2's Avatar
why do you say that?
didnt gap the plugs at all just bought them and threw them in. fuel system is stock
Originally Posted by Mrevann
check ur grounds.
all grounds are good. all new wire
Old 10-01-2011, 03:37 PM
joeshmo's Avatar
Check your gaps. If they are NGK's, I bet they will be under .04. I bought v-powers and they were at .033 and they needed to be .044. Same with my NGK iridiums.
Old 10-01-2011, 03:41 PM
203_EM2's Avatar
how do i know where they need to be? at .044 also?
Old 10-01-2011, 03:46 PM
joeshmo's Avatar
Check the manual, but I believe it is .051" for b16.
Old 10-01-2011, 03:58 PM
203_EM2's Avatar
alright ill check that out and see what happens. thanks for the help
Old 10-25-2011, 05:03 PM
203_EM2's Avatar
ok bringing this back, replaced the dizzy with new cap and rotor and nothing. We pulled the plugs and replaced them did a valve adjustment, the car ran good for 2 days then started to break up again. Car only does it at WOT if i hold it at 1/2 throttle and bring it to like 7k it doesnt do anything... anybody have any suggestions? this is getting really annoying.
Old 10-25-2011, 05:27 PM
GDD Black Reject
Mrevann's Avatar
make a video or something please
aingoldcb7
04-05-2011 08:51 PM
patrick3319
03-24-2010 09:39 PM
milanocivic
02-20-2009 08:26 PM
EFz6er
08-20-2005 03:37 PM
EK9 B16B TSL
15
02-12-2005 12:38 PM
Quick Reply: Lsvtec in 96 hatch breaks up in high rpm
