LS/VTEC swap brake booster question
Hey i got a question about the brake booster hose.. is there supposed to be a check valve or something on the hose? every time i hit the brakes the idle flucuates.. id assume there should be but i figured id ask.
its a b18c head and intake manifold in an EK for reference.
Oh another question.. i put a lightweight flywheel in too.. 8lbs.. would this make the engine stall if i take it out of gear at a high rpm? maybe i need to increase the idle a little? iacv sluggish? anyone else have a problem like this?
Re: LS/VTEC swap brake booster question (VTEC-DA)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VTEC-DA »</TD></TR><TR><TD CLASS="quote">There isnt a check valve or anything.</TD></TR></TABLE>
Yes there is. The brake booster hose has a one-way valve either in the hose (Civics) or between 2 pieces of hose (Integra).
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by geebs »</TD></TR><TR><TD CLASS="quote">Oh another question.. i put a lightweight flywheel in too.. 8lbs.. would this make the engine stall if i take it out of gear at a high rpm? maybe i need to increase the idle a little? iacv sluggish? anyone else have a problem like this?</TD></TR></TABLE>
No, it shouldn't stall. Your IACV probably isn't working well enough to compensate for the accelerated drop in engine speed.
Re: LS/VTEC swap brake booster question (Blk00EJ8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blk00EJ8 »</TD></TR><TR><TD CLASS="quote">
You're right. Its been a while since I have answered any technical questions. Guess I should brush up a bit before I repond.
i looked at a friends 96 civic and it has a check valve.. so i think im gonna go find one and throw it in there. I have an iacv sitting around.. ill have to test it out..
thanks for the replies.
djnikko
11-05-2004 08:02 AM
swiftstyles
01-12-2004 02:12 PM
