LS VTec For SALE!!!
LS VTec For SALE!!!
Asking $5000
The motor is complete and ready for swap
The motor has about 6K on it built by Elton Lo and Raceline Development in southern ca. It was never dynoed but figured to be putting out around 170-180 hp
The LS block has brand new OEM LS USDM Rods and new JDM CTR oversized pistons.
The Head is JDM ITR with all OEM Internals (Cams,Valves, Retainers,and Springs)
The Intake Manifold is a P73 JDM ITR with OEM Throttle Body and 370cc injectors
The Tranny is B16 Hydralic and eatures a six puck ACT clutch and ACT Flywheel
The ECU is a programmable P28 Hondata Unit (pre-programmed)
Extras included:
All motor mounts (sorry no axles)
EK harness
Alternator
Shilft Linkage
Slightly used oil pan... The motor has a slight oil leak from the pan (you will need a new gasket)
Toda Timing Belt
JDM ITR 4-2-1 Header w/ heat shield
Also a new starter was put in at a about 3000 miles
Also included is a custom straight pipe w/test pipe (no cat) 2 1/4'' mandrel bent
I am new to this so If you want pics email me at chrislopez05@comcastnet
Extras included:
EK harness
Alternator
Shilft Linkage
Toda Timing Belt
Ek9ReVciVic
Northern California (Sales)
05-25-2007 06:24 PM
