ls/vtec
ls/vtec
How long should i expect the life of an ls/vtec motor to be with normal driving and rarely punching....and the work is doen right as in blueprint block,balance crank, take head to machine shop etc....with b16 pistons and gsr injectors.....????..............thanx
Re: ls/vtec (Lookincrazy)
there are people that I know that have had it for over 50k miles with no problems. Be sure to break it in all good, and do car maintenience more then a normal motor.
If built correctly with good quality parts it will last a good amount of time...
LS/Vtec needs a little more maintance than a regualr b16 or b18c swap..If you take care of the motor and break it in well it should last you a while...
Re: ls/vtec (Hatch_92)
what kind of maintenance stuff do i need to do to keep it in good condition? U guys are saying it needs extra maintenance so what do i need to do and how do i break it in?
1 Post
maintenance is the same as with any motor. just be more thorough about it and the main thing to watch is oil pressure. have a gauge to monitor that so you know if the oil pump might be going out.
but other than that, basic oil changes, etc. will do fine.
have fun!
Wil
have fun!
Wil
Re: ls/vtec (exospeedAMcrx)
Yep, brake in is key. I changed my oil three times within the first 1000 miles. I also did not hit VTEC for the first 1000 miles. I use 20w50 oil in mine. I have just over 10,000 miles on it now with no problems.
HT White Ops
So, to answer your question, driving it "normal" and "rarely punching" it - it'll last as long as any other Honda motor...
HT White Ops
Re: ls/vtec (DragonCTR69)
Then what is the point of building an LS/VTEC?...
dc2LS
01-28-2013 05:32 AM
