LS vs GSR vs Si Transmission??
Does anybody know the differnce between the LS ,GSR, B16 99 si Tranny? I have a 99 Civic Si....but my third gear keeps scratching everytime i shift above 4grand...I think something is wrong with my synchoros...tranny shop said to fix would be above 1K...so i say I minus well buy a new transmission and just swap it in..i think it would be cheaper...what do you guys think?
Re: (Lil Corb)
<FONT COLOR="royalblue"> Stay away from the LS trans. The diffrence between the GS-R & Si Trans is minimal. Try some GM Syncro Mesh and if that doesn't work, Good Luck. </FONT>
Re: (dogfood)
ls tranny has longest gears, good for a turbo setup, gsr tranny gears are a little shorter than ls, and b16 is the shortest of them all as stated above...unless you are going boost stay away from an ls tranny a buddy of mine had an ls tranny on a b16 and it was something awful
Solbros Owns Me
Re: (CA6VTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CA6VTEC »</TD></TR><TR><TD CLASS="quote"><FONT COLOR="royalblue"> Stay away from the LS trans. The diffrence between the GS-R & Si Trans is minimal. </FONT>
i agree.. stay away from the LS tranny.. but thereis a HUGE difference between the GSR and Si transmissions. Si is WAY better for allmotor, and arguably better for turbo also.
Re: (Evs-One)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Evs-One »</TD></TR><TR><TD CLASS="quote">
i agree.. stay away from the LS tranny.. but thereis a HUGE difference between the GSR and Si transmissions. Si is WAY better for allmotor, and arguably better for turbo also.</TD></TR></TABLE>
<FONT COLOR="royalblue"> 1st gear is the same and 2nd & 3rd have about 6mph between them.
I agree 100% about the Turbo comment. LS tranny is just myth, when it comes to turbo. Really about user preference. Give me an Si Trans W/ LSD and I'm a happy man. </FONT>
Re: LS vs GSR vs Si Transmission?? (everlasting1832)
Search for this. I am not trying to be a dick saying that either
But i seem to remember somebody posting the gear ratios for each.
GSR and SI share similar gears down low but end up with different final drives if i remember correctly.
Re: LS vs GSR vs Si Transmission?? (2KCivicSiR)
Found this website when i searched H-T
http://www.ff-squad.com/tech/temp/Bgears.htm
Has Gear ratios for all B Series
definatly try out the gm syncromesh. it helped one of my trannys. if you dont feel like spending 12+ dollars per quart, pennzoil syncromesh in the yellow container is the same stuff
Re: LS vs GSR vs Si Transmission?? (blackeg)
Syncromesh..never heard of it....is it a different transmission fluid? or is it just a fluid enhancement for the tranny fluid?
TSPeed Factory
Re: (Icey112)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Icey112 »</TD></TR><TR><TD CLASS="quote">so what tranny would you'll use for 200hp allmotor and a125 shot of nitrous?
im rocking a shitty ls tranny it does suck .</TD></TR></TABLE>
civic si tranny . or even an ITR or CTR if you're a baller.
Re: (Icey112)
Damn thats a lot of nitrous
I see on the specs that the B16 had the exact same ratio's at the ITR tranny. Damn this really pisses me off to find out that I have a ITR replica and its funked up! and B16 trannys are hella pricey..Imma have to get a GSR tranny. they run like 3x cheaper then the b16 tranny...and do you guys know the difference between cable and hydro? the cable B16 are still pricey..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by everlasting1832 »</TD></TR><TR><TD CLASS="quote">I see on the specs that the B16 had the exact same ratio's at the ITR tranny. Damn this really pisses me off to find out that I have a ITR replica and its funked up! and B16 trannys are hella pricey..Imma have to get a GSR tranny. they run like 3x cheaper then the b16 tranny...and do you guys know the difference between cable and hydro? the cable B16 are still pricey..</TD></TR></TABLE>
<FONT COLOR="royalblue"> You don't need cable. Start looking on H-T Claassifieds, everyone & awhile you run into good bargains for B-Series Hydro Trannies. </FONT>
I have a 2000 Honda Civic Si with the Si manual tranny. I race Pure Stock on a 1/3 mile asphalt oval. I’m hitting the rev limiter just past half track. I would like another 20/30 feet before I hit the limiter. What tranny would work best for me?
I run second gear, third would not work with this tranny, not enough torque out of the corners.
P.S. I found this thread through searching, I hope the original poster doesn’t mind me posting this.
Thanks!!
Thanks!!
Thanks!!
Thanks!!
Thanks!!
Thanks!!
B18 CYA
12-03-2008 05:38 PM
