LS-Turbo over heating problems
okay, i just got my car running after like 4 months...but now i got another problem...my car starts, runs, boost, but after driving around the block like 2 times, the temp gauge goes up super fast...i park my car, and open my hood..the motor is hot, the top of my radiator is hot, but the bottom is cold..WEIRD...and now my heater doesn't work too...just yesterday, i had to take out my radiator, and wash it out with hot water because i had water sitting in there and froze up...and then i filled it up with coolant....got my fan working...but still over heats.....any ideas????
Location: CAPITAL CITY Tallahassee D.S., Florida, U.S.A
1 Post
Re: (sherm_vaj00)
first check the thermostat.... if that is ok...pressure check it and also make sure your fans work check the rad cap as well.....keep us posted could be other things but these are easy to check
Re: (Throwdown)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Throwdown »</TD></TR><TR><TD CLASS="quote">first check the thermostat.... if that is ok...pressure check it and also make sure your fans work check the rad cap as well.....keep us posted could be other things but these are easy to check</TD></TR></TABLE>
OP said the rad is hot. If the thermostat wasn't opening the rad wouldn't be hot since the water is closed off and only circulating the block.
On the flipside, usually when you remove your rad extra debris goes into the thermostat and you have to change that too, so change the thermostat first, and then see what happens from there.
Sounds like a blockage - thermostat would create a blockage - check the thermostat first.
okay guys, i'll check on the thermostat...but one thing didn't mention...before i used my chip ecu, i borrow one of my friends ecu...the car ran okay, but it didn't over heat...and my heater works as well...could it be that i left my car outside and the water froze inside?????becuz all i did was wash out the ice in the radiator, and hoes only...and whats with the car reving up to 2,500 rpm and going down and goes up again..and keeps doing that??
now i have another problem...im not getting any fuel when i start up..ussually i can hear the fuel, but sumhow it's not working, plus my fan doesn't work now too..could it be sum wiring problem????
okay..i got my car to start up now..it was becuz of a loose wiring next to the thermostat...but still my car is over heating after i changed the thermostat...what could be the problem????and why does my car keep reving up to 2,500 and goes down to 1,000 rpm and goes up and down..and keeps doing that...and my heater still doesn't work...could it be one of my relay???? how can i check if my relay isn't gew anymore??
