LS swap into 92-95 Civ Coupe, Motor Mount Question
I know if using 94 and up B18 or B18C that motors mounts are direct fit and will work perfectly. I am putting in a 91 LS b18, which is a 2nd gen Integ I think, will the stockie 3g Integ motor mount fit or will I have to get a kit?
Re: LS swap into 92-95 Civ Coupe, Motor Mount Question (swaytec)
Thats what I thought. Basically the 2nd gen is the same as the 3rd gen all except for the Intake manifold. The 2nd gen has the PGMI Fuel set up. Thanks much all who replied. I wasn't gonna do a swap this early. I just got the car body done two days ago and find out the D15 had a hiarline crack in the block. Later that day I scirbied across the LS swap for $500 ( everything but tranny and axles ) can't beat that. Later I'm V-tec/LS with a GSR Head and throw bout 16 lbs of boost with a 16g./ Hopefully I'll be done with that by mid-summer. Then I can ride around "Like a Pimp", in the words of David Banner.
Re: LS swap into 92-95 Civ Coupe, Motor Mount Question (mericbe)
the easy way to do it is to take the mount off the block(91) and put the mount for a 94 up back on then you can use the 94 up stuff
Re: LS swap into 92-95 Civ Coupe, Motor Mount Question (saleensolution)
Yes SALEENSOLUTION, I planned on doing that. I actually dont have that mount from a 3g. But I have my handy Honda Dealer her and Hasport has it too. Its not too bad to the Wallet, on Hasport that rear mount is only $75. But I can always find one somewhere else too
cowboys22cardinals22
13
06-02-2008 10:13 AM
boosted3g
12-28-2002 12:25 PM
