LS motor in a '93 civic SI????
I need to know what mounts, and injectors to use. Since the LS is OBDII, can I use the distributor from it? Also, the LS motor was on an automatic, and the PCV valve is on the valve cover instead of on the intake manifold/oil chamber. Infact , the motor doesn't even have an oil chamber under the intake manifold like the GSR's and B16's. Can I leave the PCV valve there, or do I need to get an oil chamber?I would appreciate any advise.
Thanks
Thanks
Re: LS motor in a '93 civic SI???? (ITRCRX)
You will need to use either all 5 spd LS mounts, or go buy Del Sol mounts from Honda if your LS does not have the mounts you need. All non vtec motors do NOT have the recirculation tank you refer to. Only Vtec engines have it whether or not they are and A/T or a M/T. You will need to use OBD1 injectors, unless you want to use the OBDII's and wire the OBDII plugs instead of the OBDI plugs, and you can use the dist. from the OBDII you will just have to change the plug to OBDI.
Hope that helps.
Hope that helps.
Re: LS motor in a '93 civic SI???? (Kikomon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kikomon »</TD></TR><TR><TD CLASS="quote">search! </TD></TR></TABLE>You're a good one for that
