LS ABS in my EG??
LS ABS in my EG??
I plan on swapping an LS engine (axels, ecu, everything..) into my VX this spring and was wondering if this will give me ABS or if i have to do something extra as well.
Re: LS ABS in my EG?? (jonesin4abeer)
You would have to do ALOT extra like running hard lines, abs sensors, and unit ..Which I've never seen done and I dont even think it can be done without alot of modifcation . So no you will not have ABS .
you might be able to get the abs system off a 94-95 si hatchback since it was the only hatch that ever had abs and this would be the easiest way to do it.. you would also need to get the rear disc conversion as well and that in itsself is a big upgrade!
