lowering with stock UCA's 97 ex
So im was wondering if there are any limitations on how far you can lower 97 ex front upper control arms with the Ksport coilover damper setup? or is it still able to hit the 0-4" mark with stock ones.
Think i will have any rubbing problems with 15" slips and 195/45/r15 on with what ever ammount of drop i plan on doing? |
Re: lowering with stock UCA's 97 ex (spotscivic)
if you drop 0-2'' i think youll be fine as far as tire rub, any lower than that and your going to have bigger problems with your car bottoming out. putting aside bottoming out and all that the stock UCA's should accept a drop that exteme, however your camber will be significantly affected
