Lowered, are camber kits enough?
I recently got a 94 EX that is already lowered. It sets about 3in off the ground. I was wondering if the camber kits you see on Ebay have enough adjustment to get the camber back in spec? The max adjustment is +3 degrees front and rear. Is that enough? I'm just wondering cause the wheels are really tilted in at the top.
Re: Lowered, are camber kits enough? (Big Red 211)
yeah i would get the front and rear camber kits and get an alignment. the toe casn also effect the tread wear
AKA MoDeL FaWken JERKz
Re: Lowered, are camber kits enough? (fmrprojects)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fmrprojects »</TD></TR><TR><TD CLASS="quote">yeah i would get the front and rear camber kits and get an alignment. the toe casn also effect the tread wear</TD></TR></TABLE>
be professional
3 inches from the ground? If you're that damn low, you're going to have clearance issues with a camber kit. Raise the car up off the bump stops.
i have omni power upper control arms, probably the most adjustment you can get, there is a pinch weld type thing that limits the length of the upper control arm which in turn limits the adjustment on the ball joint. You're looking at minitrucker type gear like drop spindles when you want to go "slammed" and have good camber.
Re: Lowered, are camber kits enough? (Targa250R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Targa250R »</TD></TR><TR><TD CLASS="quote">3 inches from the ground? If you're that damn low, you're going to have clearance issues with a camber kit. Raise the car up off the bump stops.</TD></TR></TABLE>I've noticed it already, I can't pull the car into my garage with out the floor pans dragging a little, and muffler.
http://cgi.ebay.com/ebaymotors...%3AIT
That's the kit I was thinking about getting. Has anyone used that style kit before? How low was your car dropped?
I <U>WOULD NOT</U> let that crap touch my car.. something very important like the suspension, you should use brand name.. quality parts.. not some unknown stuff from ebay..
brand names: ingalls, omni, skunk2, spc ..
I cursed out BauleyCivic and got banned
Re: Lowered, are camber kits enough? (haveaniceday)
that **** kinda looks cheapo to me go to jcwhitney and look for ones u like and then go to the actaul company read up about it then order from something other than a catalog to save some money
Re: Lowered, are camber kits enough? (96accordlxf22b2)
does anyone know what the camber on an eg civic should be in the front and in the back?
i went to a shop to get my camber adjusted and have my car aligned and when i look at my car from the back one wheel still looks tilted in, not much but a lilttle. so i wanted to know what the stock camber is in the front and back so i can go again and tell them what to set it to.
thanx
thanx
Re: Lowered, are camber kits enough? (XkjeldorX)
where the heck did you get an alignment?
they should look it up and set it to oem spec without you having to do anything.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by haveaniceday »</TD></TR><TR><TD CLASS="quote">I <U>WOULD NOT</U> let that crap touch my car.. something very important like the suspension, you should use brand name.. quality parts.. not some unknown stuff from ebay..
brand names: ingalls, omni, skunk2, spc .. </TD></TR></TABLE>
He is absolutely right. Contact us we and will take care of you. Camber specialists for almost 5 years. http://www.camberkit.com http://www.iapdirect.com
Noah Santana
11
01-18-2017 06:09 AM
