lower timing belt cover compatability need help identifing
1 Post
i have a d16z6 and dont have a lower timing belt cover i was hoping someone on here could help me find a replacement one that fits and is accurate. (meaning it will show me the right TDC markings and all that) i was thinking d16 y7 y8 but im not 100% sure and would like a confirmation
Seagull Management
Re: lower timing belt cover compatability need help identifing
D16Z1/D15Z1/JDM D15B Vtec/JDM SOHC Vtec ZC should all work IIRC. Y7/Y8 are different because of the CKF sensor on those engines (Y8 timing is also different but I think it's the marks on the crank pulley that are different.
1 Post
i know the 96-00y-series run at a 12TDC base timing and 88-95 16TDC but im sure the z1 block is different: also i think its only on the cam gear? not crank timing different or am i wrong as for the CKF sensor i believe its a cutout but not 100% sure either. i think they all have same deck height?
Seagull Management
1 Post
oh well i only ask because im gettin a y7 cover for free for my built block so i will try that if it doesnt work ill look for a z1 thanks for help sir //// thread
ncskate
06-15-2005 07:23 PM
