need help heater dont work
Old 11-29-2012, 10:35 PM
pinoysi2000's Avatar
Default need help heater dont work
i own honda civic si 2000 with gsr engine
got a new tstat
blower blows hard but still no heat comin out.
also went to the shop and told me my hoses are swtch up and i switch them up and still no heat comin out. please need help
http://i47.tinypic.com/5btq3n.jpg
http://i46.tinypic.com/2n7eqx.jpg
thanks
Old 11-30-2012, 01:35 AM
Technical Hero
HondaPartsHero's Avatar
Default Re: need help heater dont work
Are both your heater hoses hot?
http://autorepair.about.com/library/a/1g/bl899g.htm
Old 11-30-2012, 05:42 AM
kyden's Avatar
that hose doesn't go to the intake manifold.
one heater hose goes to the water pipe under the intake manifold, the other to the nipple on the transmission side of the head.
it actually appears none of your water hoses are hooked up correctly.
Old 11-30-2012, 09:28 AM
Mintyek's Avatar
Have you check your Fuses?
Old 12-12-2012, 02:49 AM
sk8member's Avatar
Grab upper radiator hose and rev it a little ~ 3k if a surge is felt, your water pump is good. Sounds like a bad water pump to me though.
q16racer
Honda S2000
11-14-2011 10:58 AM
2kgsrt
04-05-2010 09:00 PM
mac_24_seven
12-29-2008 01:27 AM
Ohmster
04-21-2008 05:13 PM
greasemonkee
11-24-2006 01:22 PM
Quick Reply: need help heater dont work
