lower control arms..
so i have a 94 cx hatch and i have tein lowerin springs..and i was wondering if getting LCAs would it be worth it and would it make a difference on just lowering springs?
Re: lower control arms..
besides loosing a few lbs(5 maybe), no. unless u want to put a sway on one day and cant get teg ones. either way aftermarket lca's are just a bling factor...
Aftermarket front LCA's are just for the bling factor pretty much. If you're going to road race or auto cross I suggest you don't get one.
Just stick to a brand new OEM lca if you decide yours suck. lol.
Yeah I dont know what I was thinkin, tie bars dont do anything to help from tearout.. You should get an ASR brace tho to help prevent it. Those Beaks subframe reinforcement kits dont work either.
he said lca's not a SWAY BAR
please, stop...i'd hate to see someone on here take your advice.
The OP was asking if changing out the LCAs (alone) will make a difference, and the consensus is NO. Installing aftermarket LCAs won't make a difference UNLESS you're also going to install a big aftermarket sway bar (CXs don't come with the mounting holes for any sway bar). I wouldn't change the LCAs unless you're planning on doing the sway bar as well. If you decide to swap out the LCAs, you could just get some from an Civic EX 4-door or an Integra and use the sway bar designed for those. If you go with a thicker bar (like a Type-R), you'll definitely need that sub-frame reinforcement kit. Also, if you get a thick aftermarket bar, (like a BLOX) you'll need aftermarket LCAs.
fm
fm
There's always the "unbling" option for racers (matte black teflon coat):
This is a custom service that we've always offered for race/rally customers. You can custom order them with the coating, or if you send your arms in, together with return shipping, we will apply the coating. We do not charge for this service, but please contact us ahead of timeif you plan on sending your arms back to us.
-A
-A
I had to take my tie bar out when I put my subframe brace in. Having both on would have been overkill.
I got matte black blox control arms and a matte black ASR brace...nice and stealth looking...no bling factor at all.
fm
fm
Function7 FTW... They're also the lightest (supposedly), so it'd provide less unsprung weight. Not much of a difference, of course, but that could help you justify getting them.
-A
i dont mean to be an *** but i have the teflon coated function 7's and that coating dosnt stay on well at all it practically comes of with a normal handling
dc2leftovers
07-24-2009 12:27 PM
spaceman00
17
03-16-2007 11:31 AM
00siandrew
09-06-2006 08:37 PM
bebeon_ek
67
07-07-2005 09:53 PM
