Low idle no matter what I fix
My 99 Civic with mini me swap I've literally done everything to fix it and only code it has is iac, my question is will iac make car idle literally at 100 and make it very hard to start when it's warm
Re: Low idle no matter what I fix
there is no one hundred.
Yes, if the IACV is not functioning, the idle will be very low... almost stalling... but it is actually under 500 rpm.
Test the IACV with an ohmmeter. If the coil is open circuit, replace IACV. If the valve is OK, check that the correct plug is plugged into it and that the wiring is OK. The code is telling you that there is an electrical problem with the IACV circuit. So I don't know why you went out replacing "everything else".
Originally Posted by mk378
(Post 51912632)
Sounds like you are operating at base idle, (around 400). You need to get that IACV (Idle Air Control Valve) circuit fixed in order for your car to idle correct.
