low idle
low idle
anybody know if a motor built for boost with low compression pistons in will idle low or could it be my cel. throw a atmopheric pressure sensor code. i also think i need it retuned cause the turbo has been on about a year an half. b16 motor incase you need to know
low compression isnt going to cause a low idle.
fix the obvious first (CEL) and get it tuned. if everything is fine the tuner can adjust the target idle with the program he uses.
