loud vtec crossover
#76
Former Moderator
Re: loud vtec crossover
You should hear that "pop" noise at 4500rpm followed by a slightly throatier resonance once the secondaries open up at 5800-6000rpm.
See maybe this topic can be salvaged with some actual tech info after all.
#77
i have a jdmb16a and i just got my ecu chipped... p28 running p30 basemap tuned on crome pro... I have vtec set to 4800.. and i feel like im losing top end power but midrange i gained... did i set vtec to low?.. i feel like it takes forever to get to 100 now..
#79
#80
Yes I would set it higher if I were you, try 5300.
#81
#82
#84
that sounds like when my vtec hits but it pulls pretty good and "cracks" hard. but its hard to tell cause i build full boost about the same time. :/ im only a single cam tho...
#85
#86
be professional
The safest point to set the engagement is 5600 RPM for a USDM B16A and 5800 for a 2nd-generation JDM B16A. It's not ideal, but it's better than just guessing without a dyno plot.
#87
...I always read about and heard about havin loud vtak was in the head work (cams, porting, intake mani, headers, intake, and even the sought after misterious "big" vtak solenoid) I myself have had a gsr, poor mans type r, and now a fully built b16b, and out of all these swaps I gta say the b16b has hit and pulled the hardest,
On the full gsr I just had ctr tranny, and dc headers only
On the poormans I had b18c1 block ctr pistons, ctr head (complete) ctr headers, pwjdm carbon intake
On the b16b I have benson sleeves, jun stroker (2.0) p&p 5angle ctr head jun spec 3 cams toda valvetrain, toda itbs, rmf headers, bc spec 2 exhaust. Quaife ctr tranny
And for all u that are lookin for the "big" vtak solenoid cuz its louder and faster engaging, ITS TRUE!!! I swapped mine to my friends b16a2 eg hatch and it made a big difference soundwise and trackwise...
(Loud)VTAK FTMFW!!! Lol
#88
be professional
It's a freaking spool valve. It has nothing to do with anything.
#89
I'm not Rick!
plug it in and go to GET on the tool bar and get your map and options and change vtec..wala. your afr will be a tad off right before vtec though
#90
i had open header on gsr swapped ek for a week
chipped ecu and s2 im
vtec was real loud
got my hks hi power back on now
u can bearly hear vtec
maybe get some r cams
vtec was real loud
#91
thank you... im knew to the tuning.. its tuned on crome pro.. so i have a laptop.. what port do i plug into the laptop
#92
I'm not Rick!
what port?
depends, do you have a data cable (usb) coming from a black box(ostrich)
or did you have a chip burned?
chips suk. buy a moates ostrich 2.0 $175 and you can put that into your socket and tune. and plug that right into your computer. go to moates.net and download the ostrich driver(free) youl neeed that for the laptop to recognize the usb to ecu
#93
Likely your comparing the American b16 medium buzz sound To what I think you had the b16 out of the integra xsi from Japan It had 10 more hp making 170crank the biggest difference was more aggressive cams.. I had an xsi b16 and eventually threw it on a b18 bottom end...that FlunKer Creeeeamed!!!! .....Or was that mE...
malo11
21
12-24-2022 04:57 PM
sportinjected
05-29-2008 05:56 PM
