Loud screeching sound on start up, then car dies......
there is a loud screeching sound on start up, then the car dies, the a/c belt is tight as hell, but the alternator belt is looser than that, do you think that could be the crank not being in sync with the alternator belt? its a minime y7 y8 engine.
Re: Loud screeching sound on start up, then car dies...... (Civiclx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Civiclx »</TD></TR><TR><TD CLASS="quote">there is a loud screeching sound on start up, then the car dies, the a/c belt is tight as hell, but the alternator belt is looser than that, do you think that could be the crank not being in sync with the alternator belt? its a minime y7 y8 engine. </TD></TR></TABLE>
SCREEEEEEEEEEEEEEECHHHHH ....<engine dies>
tighten the alternator belt ,..see if that fixes your problem,..i dont see how it would make it die though,..well i mean it could because once the car starts,..it runs off the alternator,..because the car only really uses the battery to start up
Re: Loud screeching sound on start up, then car dies...... (WiDeBoDyEK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WiDeBoDyEK »</TD></TR><TR><TD CLASS="quote">tighten the alternator belt ,..see if that fixes your problem,..i dont see how it would make it die though,..well i mean it could because once the car starts,..it runs off the alternator,..because the car only really uses the battery to start up </TD></TR></TABLE>
see thats what i was wondering, lets say the alternator belt tightening kills the screeching sound, what would cause it to idle bad and then die, the IACV or timing?
see thats what i was wondering, lets say the alternator belt tightening kills the screeching sound, what would cause it to idle bad and then die, the IACV or timing?</TD></TR></TABLE>
both the IACV and timing can cause a rough or no idle,...are you throwing a code for the IACV? last time you cleaned it? and are you sure you timing is right,..alot of things can cause bad idle,..like vaccum leaks and **** like that
i am almost certain that the timing is right, i set both the crank and cam gear to tdc before i put the belt on and made sure they were both at tdc settings with the belt on.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Civiclx »</TD></TR><TR><TD CLASS="quote">i am almost certain that the timing is right, i set both the crank and cam gear to tdc before i put the belt on and made sure they were both at tdc settings with the belt on. </TD></TR></TABLE>
tighten the belt and see if that does any help
Remove both AC and alternator belts try and start the car and see if it maintains idle. Reinstall one at a time while starting car up with each one on seperately. May be a seized up clutchpack/compressor or seized alternator. Is it screeching like bearing metallic whaling or just a belt slip screech. That would cause your car to idle incorrectly and possibly stall due to the added load of the seized component.
Re: Loud screeching sound on start up, then car dies...... (BauleyCivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BauleyCivic »</TD></TR><TR><TD CLASS="quote">you just can't win can you dude?
Feels bad that he doesn't know how to fix any of your problems </TD></TR></TABLE>
dont worry about it man, im just frustrated right now
Re: Loud screeching sound on start up, then car dies...... (Caleb V)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Caleb V »</TD></TR><TR><TD CLASS="quote">Remove both AC and alternator belts try and start the car and see if it maintains idle. Reinstall one at a time while starting car up with each one on seperately. May be a seized up clutchpack/compressor or seized alternator. Is it screeching like bearing metallic whaling or just a belt slip screech. That would cause your car to idle incorrectly and possibly stall due to the added load of the seized component.</TD></TR></TABLE>
Yup.
Yes, as long as your battery is fully charged, you can run it with no alt or A/C belts on it.
Yup.
higgunscrx
06-15-2006 05:11 PM
xstalkrx
10-24-2003 03:30 PM
