loss in horsepower due to altitude?
hows it going...i recently moved to colorado from houston and due to the altitude i have a loss in horsepower it feels like due to the thinness of the air up here...im at about 6500 ft compared to houston which is sea level...anyway to compensate for this and /or boost power to sea level ratings?? gsr in an ek. Thanks ahead.
Re: loss in horsepower due to altitude? (ekfighter)
Any motor you put in there you will lose power compared to what it would do at sea level. I would boost. If you have the money gsr THEN boost! https://honda-tech.com/forums/images/smilies/emthup.gif
Re: loss in horsepower due to altitude? (murtnabila)
Yes I agree...guess not much i can do but boost it. This is my first Vtec motor so im still learning. Good news is its still an even playing field up here because everyone's motor runs the same. Somewhere I heard that if you unplug ecu overnight and replug in the morning over a period of a couple of weeks then the ecu will adjust to less oxygen in air? I dunno. Any truth to this possibly? Thanks again.
bumppety bump.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ekfighter »</TD></TR><TR><TD CLASS="quote">Somewhere I heard that if you unplug ecu overnight and replug in the morning over a period of a couple of weeks then the ecu will adjust to less oxygen in air? I dunno. Any truth to this possibly? Thanks again. </TD></TR></TABLE>
You're talking about resetting the ECU by unplugging the negative terminal of your battery. It does not need to be done overnight. And yes, it will allow the computer to adjust to the new atmosphere, but so will driving around for a few days. It doesn't matter, though, because you still won't regain any power. Higher altitude = less oxygen for your motor = less horsepower. Nothing you can do about it unless you force more air into your motor through a blower or turbo. https://honda-tech.com/forums/images/smilies/emwink.gif Or you could move back to TX. . . . |
Re: loss in horsepower due to altitude? (Daniel)
yup, forced induction or lower altitude is your only way.
Re: loss in horsepower due to altitude? (sanya_sk)
Agreed gentleman...thanks for the info...moving back may become a higher priority!!!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ekfighter »</TD></TR><TR><TD CLASS="quote">moving back may become a higher priority!!!!</TD></TR></TABLE>
No pun intended. https://honda-tech.com/forums/images...s/emsmilep.gif |
