Losing Oil. Lost Two Quarts in 600 Miles . HELP HELP
Guest
Posts: n/a
What could cause my car (99 Civic Si B16A2) to lose oil like this? Theres no oil stain or no black or white smoke coming out my tail pipe. I have a full warranty on my ride . 100Gs but Im ready to turbocharge my car and this is just ******* everything up. My compression is all fucked up big big time . 110 125 150 109 . WTF is going on. I could not see any oil around my parking spot. So a leak is out of the question but in the morning it does throw smoke. I dont know what going on please help me.
Re: Losing Oil. Lost Two Quarts in 600 Miles . HELP HELP (BOOSTINSI)
Seems very strange. With rings you usually have smoke under acceleration. You mentioned your car was under warranty, make it the dealers problem
Try doing a wet and dry compression test. See if your compression goes up with the wet test.
Seems like you need new rings. If that's the case, take it to the dealer and let them handle it.
Re: Losing Oil. Lost Two Quarts in 600 Miles . HELP HELP (Halo)
Re: Losing Oil. Lost Two Quarts in 600 Miles . HELP HELP (Hybrid93Hatch)
Dood, if you have the extended warranty, without a doubt take it to Honda and have them check it out and repair it. Did you have any other mods besides the AEM CAI in the past? Also, what oil are you using, Mobil 1 synthetic? If so, try another oil. You might wanna put your stock airbox in before you take it to the dealer so they don't break your ***** and say the car "has been modified".. etc.. You know they can be real ******.. Take the car to Honda ASAP!!! Good luck..
Guest
Posts: n/a
Re: Losing Oil. Lost Two Quarts in 600 Miles . HELP HELP (chameleon)
Hell yeah im took off the Cai before I took it . Them fools are *** holes. Anyways I took and they did an oil connsumption test and I lost two quarts in 560 miles. So I took it back and they said come back on the 24th to do a diagnostic..........I got lazy and didint take it im gonna take it tommorow. ONE MORE THING COULD CARBON BUILD UP CAUSE THIS?
its your rings for sure.
Re: Losing Oil. Lost Two Quarts in 600 Miles . HELP HELP (spoon_ek9)
no, it cant be.
no, it cant be.
Re: Losing Oil. Lost Two Quarts in 600 Miles . HELP HELP (00MRSi)
A little carbon buildup will bump up your compression..
These are my numbers ... 190 180 190 210
So im told our motor (B16A2) should have 190~210 lbs per sq. in
Take it to the dealer and let them fix it!! Put back all your stock stuff so they dont give you a hardtime.
94allmotor
15
09-25-2007 05:31 PM
