Loosing faith in Mechanics - Honda Civic 1993 issues!
I have had 2 different diagnosis from 2 different mechanics for issues of black smoke and high idling with my Honda Civic 93, DB15 engine with twin carby, manual, AC.
I have lost my faith in mechanics and I would like to know opinions on what I should do. Should I fix it myself??? I have already replaced the fan switch, O2 sensor and have had a major service done.
The car blows black smoke, even after a major service. Once warmed up, it would idle at 1800-2100 and the black smoke usually disappears. The black smoke is due to a fuel and air mixture issue which results in my car only getting 300-340klms per full tank, than before where it use to get 480-550klms per full tank. I presume this is due to the high idle and fuel mixture/black smoke issue.
It struggles to stay idle at less than 1600rpm, so when I first start the car in the morning, I would have to drive it around till it gets warmed up otherwise it dies or otherwise, I have to rev the car when at a stop at about 1800rpm for it to remain running.
1st Mechanic diagnosis-
sticky choke
valves need adjusting to fix black smoke
2nd Mechanic
Carby requires overhauling
Choke/Wax pellet not working
Power vale fault(I presume its a mistype and should say valve)
Vacuum leak from carby intake rubbers
I tend to believe the 2nd mechanic since they were recommended by a close friend who has been going to the same mechanic for over 10 years.
Are the faults listed from the 2nd mechanic DIY'able? Would I be better off buying a used twin carby or engine? What are my possible options because I have spent almost 4K on this car on repairs alone and I have only had it for a few years!! Now I have to spend more!!! I could have spent for a later model car at the start if I had known this car would have had so much issues!
Any help, opinions or advice appreciated.
sticky choke
2nd Mechanic
Re: Loosing faith in Mechanics - Honda Civic 1993 issues!
not many mechanics know how to work on carbs ... you would probly have better luck going to a old school muscle car shop lol, were they still use cars and know how to tune em ... sounds like you just have a loose screw or something dumb that fell apart in the carb. IMO you would just switch over to a d16 with, direct port injection from a yard .. or you can do a b swap if you want more power.
You're running crazy rich.
Edit: If you feel up to it you can rebuild the carb yourself. There are a LOT of small parts so keep that in mind. Otherwise send it to the second mechanic. You could search a junkyard for a used one but that could be hit or miss.
rebuild your carbs, im 22 and know carbs, its a shame noone knows how to work on them. it could be as simple as adjusting your mixture screws and leaning it out a little bit.
I think my carby is computer controlled?? That is why I changed my O2 sensor to help fix the fuel and air mixture which sort of worked at the start and now it is back to black smoke again.
i would unhook all the computer junk and run the carbs manual. im not sure how honda carbs are, but my old 86 f150 inline 6 had a computer controlled carb. i pulled all those wires right out of there, wired the electric choke to a potentiometer, and called it a day.
