looking for someone with power folding mirrors, not installed...
Re: looking for someone with power folding mirrors, not installed... (b16acivic00)
If you have em uninstalled and you look at the mirror, youll see that white harness attached to it. I need to know how the wires go into that harness. Meaning if you lift off the weather gasket and remove the 2 screws holding down the white harness, pull the harness out and tell me what color wire goes into what holder ad matches to what wire on the black harness.
If you need a pic I can get you one or if you need me to call to explain it better I will. Thanks so much..
Re: looking for someone with power folding mirrors, not installed... (C-West Civic)
i took the weather strip apart and un-screwed the connector, top pin starting from the left as if you were looking directly at it yellow w/white stripe,next one is teal or a blue/green color, next one is blue w/ black stripe, next is white and there is one more that goes directly underneath the white wire and that one is black.
let me know if you have those colors and i will let you know about the black connector
yup those are the colors I got ( sweet ). SO when your lookin at the white harness on the mirror, the snap box thingy is on the bottom right?
If thats a yes, the wiring should be like this correct?
Black harness / White harness
red/yelloww - black
red/blue - white
blue/red - blue/black
blue/white - blue/green
blue/green - yellow/white
this is the right side mirror also correct?
red/yelloww - black
red/blue - white
Correct the snap thing is on the bottom and it is the right side mirror, im looking at the wiring right now ill let you know in a bit
it looks correct, you have pins that look like this----- ....
. inside the white connector?
If thats 4 across top and 1 below far right then yes. I got a blue/white in left upper corner, red/blue in upper right corner and the red/yellow on bottom row right side. This is coming off the black harness now.
alright, left side mirror snap on bottom, left to right yellow/white,yellow/red,yellow/black,black, and white wire goes directly under black one. let me know if you have those colors on this mirror?
once plugged in, like the right side, black harness should be
blue/white
yellow/white
mint ( ? )
red/yellow
red/blue ( the lone wire on bottom row )
blue/white
yellow/white
mint ( ? )
red/yellow
sweeet.. thx bro, really appreciate this... wouldve sucked to have these and not be able to hook em up.
I owe you a beer ( or few ) sometime.
I know what cha mean mine are headed for paint to match tomorrow, and then install when i get them back. but im glad i could help.
yea thats where mine have just came back from ( well the whole car really ) I took em apart for paint and lost the damn paper I had the pin location written down on...
