locked radio please help
Re: locked radio please help (EK79)
just call the dealer, make sure u have the vin number and the serial code for the radio.. they should be able to help you out... thats what i had to do for my si radio.. and make sure you write it down.. i got that **** memorized!
Is it a factory radio? If so check the owners manual sometimes the code is in with the paper work that you get with the car. The second thing to try is to pull the radio out of the dash and look for 4 digits stamped in ink on the case. It could be on the outside or under the top cover. If non of that works then talk to the honda dealer they should be able to get it for you or have be able to reset the code for you.
acuradrivr
Audio / Security / Video
09-20-2004 01:54 PM
