a little DIY
a little DIY
ok i had problems w/the pluming for my greddy catch can. every line i used would collapse under heat and vacuum. silicone line didn't but oil and silicone don't mix and the hose would degrade. so i swapped over to SS -6AN fittings and braided line. i used to 90deg -6an hose ends for the lines. (i suggest one 90 and one 120 but the 120s were back ordered so i went w/another 90) the 120 will not put the hose going to the manifold at such a radical bend.
part numbers: all Russell Endura finish:
90deg ends x2 = 610161
special adapter to go from 5/8 to -6AN x2 = 640201
you need the adapters to run the hose ends. this may be overkill but it looks best imo.
pics:
and another project. i cut the rails on my del sol seats so they would bolt into my EK. i know you can swap the rails over to ek rails and they will fit. but i know the del sol rails sit a bit lower then the ek ones. i did this to keep the seats low. its a little ghetto but it works
pics:
Re: a little DIY (CivicSiRracer69)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CivicSiRracer69 »</TD></TR><TR><TD CLASS="quote">looks mad hot props!!! Question where does the other line go to ??</TD></TR></TABLE>
lmao.. think a lil bit harder
pvc
pvc
Re: a little DIY (snail)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by snail »</TD></TR><TR><TD CLASS="quote">and another project. i cut the rails on my del sol seats so they would bolt into my EK. i know you can swap the rails over to ek rails and they will fit. but i know the del sol rails sit a bit lower then the ek ones. i did this to keep the seats low. its a little ghetto but it works
Holy shikt......I sat in my friends si with del sol's and they were low as **** with the ek rails. I cant believe you want them even lower!?!?! What are you like 7ft 5 in or so
phillycx
33
02-03-2004 06:34 PM
IgniteTeg
10
09-11-2002 09:34 PM
