linkage for ls swap?
an ls swap in a 93 del sol, which linkage should i get? can i modify a ls linkage? thanks
isn't the integra linkage supposed to just bolt right in like the 5g hatches?
if so, then it should just line right up dude https://honda-tech.com/forums/images/smilies/emthup.gif |
Re: (SpoonFedHatch)
you use the integra linkage, it bolts right up. this was in my EK so it may be different
Modified by foozball-26 at 8:32 AM 5/16/2003 |
Re: (foozball-26)
NOT IN A DEL SOL
use del sol v tec. the wheel base is different. del sol linkage will not work in a eg. you must use del sol vtec linkage |
Re: (boostedcivicsir)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedcivicsir »</TD></TR><TR><TD CLASS="quote">NOT IN A DEL SOL
use del sol v tec. the wheel base is different. del sol linkage will not work in a eg. you must use del sol vtec linkage </TD></TR></TABLE> thanks for clearing that up.......there's your answer buddy https://honda-tech.com/forums/images/smilies/emthup.gif |
