ligth weight crank pulley?
Re: ligth weight crank pulley? (roycivic92)
Didn't "feel" a diff... but every little bit helps in the long run... just get a CTR N1 pulley from jdmland.com - I think it's like $72 shipped.
Risky Business
Re: ligth weight crank pulley? (nub.96ek)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nub.96ek »</TD></TR><TR><TD CLASS="quote">Didn't "feel" a diff... but every little bit helps in the long run... just get a CTR N1 pulley from jdmland.com - I think it's like $72 shipped.</TD></TR></TABLE>
What part of SOHC didn't you understand?
To the thread starter: Leave the oem one on. You're asking to screw up your bottom end when you throw on an aftermarket crank pulley.
#1 Super Guy
If you want to drop rotating mass, the proper way is to lighten the flywheel
If you want to under-drive the accessories, the proper way is use under-drive accessory pulleys.
Loss of the harmonic balance cuts engine life in half.
Re: ligth weight crank pulley? (b18cx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18cx »</TD></TR><TR><TD CLASS="quote">watch out what you get, could get into oil pump problems. I would suggest keeping the OEM one. Not much gain there.</TD></TR></TABLE>
Exactly what Eric said Take a look at my thread just to prove his point
https://honda-tech.com/zero...41177
IGotNoSwap
21
09-27-2005 08:17 PM
