Light Notification
Light Notification
Is a 95' civic EX supposed to sound when you leave the lights on and take the key out? Mine doesn't. I have the Sir gauges, would that have anything to do with it? If not how do I fix this?
Re: Light Notification (sxeguy)
No civic 92-95 has a headlight buzzer...
But you can make yourself one...
Go to radio shack... buy a 12v buzzer or chime... like $3.99
Open up your fuse box (inside the car drivers side, under the steering wheel)
connect red wire to parking light, and black wire to windshiedl wipers
Works like a charm
Works like a charm
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sxeguy »</TD></TR><TR><TD CLASS="quote">Put the wires on which side of the fuse slot? and this will only go off when I turn the car off?</TD></TR></TABLE>
what do u mean on "which side"???
and yes it will only go off when you turn the car off and turn the key to I, or when you take the key out
Re: Light Notification (meagainsttheworld)
dont do it. my cousin did it and then later somehow it kept blowing one of his fuses and causing the cluster not to work.
Re: Light Notification (fmrprojects)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fmrprojects »</TD></TR><TR><TD CLASS="quote">dont do it. my cousin did it and then later somehow it kept blowing one of his fuses and causing the cluster not to work. </TD></TR></TABLE>
then he didnt wire it right...
Can anyone else confirm this?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by meagainsttheworld »</TD></TR><TR><TD CLASS="quote">
then he didnt wire it right... </TD></TR></TABLE>
Thats what I'm asking. Do you have pictures? or a diagram or slightly more detail?
the search feature on this site helps
heres a link
https://honda-tech.com/zerothread?id=446936
just strip the wires on the buzzer a bit more and put them around one connector on the fuse and plug the fuse back in... then if u want u can tape the buzzer under the fuse box so its not just hanging there
heres a link
rollinonblades
Lighting
10-29-2008 10:31 AM
