Leds in cluster
Leds in cluster
I bought some blue bulbs from auto illumination and and on my ex cluster on my 98 civic I get a white spot from the #194 bulb. I tried another blue one and same problem. I want to get LEDs but they offer so many different styles idk which one will distribute the best light. Does anyone know?
Re: Leds in cluster
it is my understanding that there are no plugin bulbs that wont give hot spots even the ones with the wide angle. ive been told u r better off getting an led strip or two and wire them in
O.G. triple O.G.
Re: Leds in cluster
When I had my old '91 SE-R, the p/o installed some LED lights for the gauge cluster. Somehow or another the bulbs started to act up and it would flash like a strobe. I'm assuming it's just some faulty bulbs.
Re: Leds in cluster
I have hot spots in my leds i put in my Lexus. But at night they all look fine. Just daytime you can really see one spot over others lol.
Re: Leds in cluster
Why don't you mist black primer over the spot that is "hot" on the back of the gauge face. If you do too much just use mineral spirits and wipe it off and try again.
It's similar to the way honda does the back of the gauge faces to distribute light evenly with the stock bulbs. It'll be like a solid gray color that fades out to a misty gray color.
Re: Leds in cluster
you just have to have the right leds. ive done multiple gauge clusters, ac controls and what not. Its just a matter of getting the right voltage and it should be fine. try to search for a forum on it. i will look later and see what leds i find for your car
Re: Leds in cluster
sounds good man, hope it works out. i ordered 100 leds at a time and when i got them i noticed i ordered the 6Volt=FAIL! but as long as you get blue 12volt they should be just fine. Who would have known changing the color of the gauge cluster leds changes the whole look of the inside of the car at night, lol
Re: Leds in cluster
http://autolumination.com/194_marker.html
use those, not leds. my leds had hot spots, those colored incandesents dont.
Re: Leds in cluster
Re: Leds in cluster
I had the same problem. I guy on my lexus forum said it was shity quaity bulbs. And also all those bulbs look like the ebay ones I ordered for my lexus cluster. Just my .02
The Grumpiest
Re: Leds in cluster
More than like I will be using one of these in combination with some LED bulbs.
http://cgi.ebay.com/ebaymotors/4-x-4...item3a60a1426a
Soon as it warms up.
Ek Forever y0!
Re: Leds in cluster
I spent about $80 on various LED bulbs trying to get them to work.
I have since spent $10 on incandescent bulbs and am far happier with the results.
Ek Forever y0!
Re: Leds in cluster
Hm can you show me exactly which ones your talking about? Under train lights I see similar things but I'm not sure if they are exact size that will fit into the OEM twist lock housing as a bulb transplant.
Ek Forever y0!
Re: Leds in cluster
I believe almost all the dash lights: Cluster, climate controls, are mostly #74 bulbs.
I'm sure you could shoot them an email. They have good customer service.
Re: Leds in cluster
http://www.hondacivicforum.com/forum...ad.php?t=45573
This worked good up until the RPM Gauges wouldn't fit anymore hahahahaha! I was so angry!!!! But a little bit of sanding and plastic melting it works! The only spots I have are where I melted off the bulbs because the RPM gauge wouldn't fit -_____-
Re: Leds in cluster
Dekorum,
The color in those switches is determined by the face of the switch. If you pull the switch face off, you'll see there's a blue backing behind the graphic. Even if you put an amber bulb in the switch, it's not going to look the same as a real JDM amber switch.
fm
fm
