leaks!!!!!!!
leaks!!!!!!!
its winter right now and this is my civic coupes first winter in canada. But i seem to have a leak on my drivers side floor. I have tried looking for missing plugs and i found one and put a plug there with a little silicone around it so it would not leak. But i am still getting a leak. where is it coming from. is this a common thing. i had a similar issue in my 90 integra but it was leaking on the passenger side floor through the blower motor.
Year 3030
Re: leaks!!!!!!!
Its probably your clutch cylinder seal. look up where the clutch pedal is and see if its leaking from that area and check the rubber seal on the clutch pedal piston. Its going to be a very greasy feeling fluid. (brake/clutch fluid)
