leaking oil on the front of block/tranny.been
* B A N N E D *
Ok so ive been leaking oil on the front of my block and tranny and also the back but thats a axel seal.
i was just wondering if the revers sensor not being there can cause the tranny to leak oil? Btw its a 97 cx tranny
Re: leaking oil on the front of block/tranny.been (ReactioN)
i have the d16y8 and i have a oil leak on the front of my motor i'm almost positive mine is my dipstick tube check that out also check your cam and crank seals
Re: (bigD)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bigD »</TD></TR><TR><TD CLASS="quote">check your distributor o ring common for them to leak.</TD></TR></TABLE>
if he said i have a bunch of noticeable oil on top of my trans and under my distributor this theory would make some sense
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by -JSpecEk*9- »</TD></TR><TR><TD CLASS="quote">pics would help out </TD></TR></TABLE>
its hard to figure out where you are describing the leak.
by ur distributor on the head there is a bleeder screw that use an alan to tighten or loosen... sometimes those come lose and oil can leak out there.... if it is take it out and put some thread lock on it and put it back in...
Re: leaking oil on the front of block/tranny.been (civ4life)
have you recently removed your tranny and swapped it? if so... did you replace the gasket for the tranny? if not, you could be leaking there. but only if you've swapped your tranny recently.
Solbros Owns Me
Re: leaking oil on the front of block/tranny.been (unsungfate)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by unsungfate »</TD></TR><TR><TD CLASS="quote">have you recently removed your tranny and swapped it? if so... did you replace the gasket for the tranny? if not, you could be leaking there. but only if you've swapped your tranny recently.</TD></TR></TABLE>
Without a reverse switch, there will be a hole for fluid to escape. Why do you not have the switch installed?
the responses in this thread just kill me
Re: leaking oil on the front of block/tranny.been (Evs-One)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Evs-One »</TD></TR><TR><TD CLASS="quote">
the responses in this thread just kill me </TD></TR></TABLE>
DO NOT HELP THIS STUPID SCAMMER SELLING BUNK ****
Re: leaking oil on the front of block/tranny.been (da9blk1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by da9blk1 »</TD></TR><TR><TD CLASS="quote">
x2
x2
