Leaking coolant from bottom of tranny...?
can anyone give me some advice...wether its my tranny goin! or i neednew seals!
thanx,
mike
thanx,
mike
Re: Leaking coolant from bottom of tranny...?
Is this car automatic or 5 speed. Sounds like a leak coming from one of the coolant hoses from the head. Check the 2 smaller hoses on the back of the head maybe one of the clamps is worn and wont hold tight any longer
5speed,gsr tranny. leaking from 4 bolts on the bottom. its not oil! ill check the hoses,thanx
It is not that hard to find a coolant leak. Posting on a forum with no pictures will definitely not help you diagnose it.
see ur from jacksonville i grew upt here,anyways as it says u dont need pix! i was changing my oil yesterday and i noticed that there was coolant(green) leaking slowly from the 4 bolts on the bottom of my tranny. ima go through and check my hoses on the back of my head...but has anyone had the same issue?
thanx
thanx
NOOOOOOOOOOOOOOO this seems to be an isolated case. You might even wanna check your radiator or reserve to see if you see coolant there also. The good thing about coolant is that it takes alot to dry it up so its easy to see
Check the hoses on the intake mani and stuff, and the sensors on the side of the head, maybe one is loose and streaming down the trans. Also, check the bolt torq on the i/m over on the side where those hoses are, there also a gasket thats in the side of the i/m gasket for a coolant passage, if you cant find the leak you may try that and see what you get
jdm_ek_noob
49
02-18-2014 02:17 PM
Highwind
Honda Civic (2001 - 2005)
04-01-2011 09:32 AM
petty$rep
18
10-12-2006 07:53 AM
