last plug...(pic)
Old 05-18-2004, 12:15 AM
onesikviet's Avatar
Default last plug...(pic)
finishin up swappin stock b16a2 back into 00si. car starts and drives perfect no problems! dunno where this one goes? green/black THANKS!
Modified by onesikviet at 11:58 AM 5/18/2004
Old 05-18-2004, 12:22 AM
2 point 0's Avatar
Default Re: last plug...(pic) (onesikviet)
i think that's the IAT sensor. goes on the manifold. i think your manifold doesn't have the plug.
Old 05-18-2004, 12:50 AM
Two_K Si's Avatar
Default Re: last plug...(pic) (2 point 0)
There is also a plug that plugs into the ps pressure switch on the steering rack. Maybe check it since you said your car is running fine.
Old 05-18-2004, 01:21 AM
Slow_Em1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2 point 0 &raquo;</TD></TR><TR><TD CLASS="quote">i think that's the IAT sensor. goes on the manifold. i think your manifold doesn't have the plug. </TD></TR></TABLE>
ide have to say the same, maybe you have a 1st gen b16 manifold?
Old 05-18-2004, 02:59 AM
onesikviet's Avatar
Default Re: last plug...(pic) (Slow_Em1)
EDIT: new pics
IAT/IAC (i assume this is the one u guys are talkin about). i think thats the correct plug i have plugged there already =\ still need help. BUmp i guess.
Old 05-18-2004, 03:18 AM
DangBruhY's Avatar
How much slack does it have? Does it seem like it goes in the back of the engine bay or does it reach up front. I can go take a look later today to see if I can find the same color wires.
Old 05-18-2004, 03:35 AM
onesikviet's Avatar
Default Re: last plug...(pic) (DangBruhY)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DangBruhY &raquo;</TD></TR><TR><TD CLASS="quote">How much slack does it have? Does it seem like it goes in the back of the engine bay or does it reach up front. I can go take a look later today to see if I can find the same color wires.</TD></TR></TABLE>
not enough slack to reach front. it will reach the fp regulator at most. any further doesnt seem right. thanks! thatd be great
Old 05-18-2004, 04:23 AM
moto27cm's Avatar
Im pretty sure it connects to the EVAP purge valve. Its a little black cannister that bolts to a tab on the IM. USDM motors have it. JDM motors dont. Yours may have broken off. It runs on a vacuum from a nipple on the back drivers side of the IM.
Old 05-18-2004, 05:14 AM
SkRiBLaH's Avatar
Default Re: (moto27cm)
reverse lights?
Old 05-18-2004, 05:49 AM
DangBruhY's Avatar
Default Re: (SkRiBLaH)
I have a JDM engine. If I don't find it, then I guess the post above is right.
Old 05-18-2004, 06:14 AM
ABK
ABK's Avatar
Default Re: (DangBruhY)
what about in the back of intake matifold on the other side from TB I think there is a white sensor (I have no clue what it is called)
Old 05-18-2004, 05:58 PM
onesikviet's Avatar
Default Re: (ABK)
well, im going to get it smogged sometime later this week, which is the whole reason why its back to stock. you guys think this will be a problem? if he(smog tech) see's that theres a plug not connected to anything. thats all im worried about. TIA
Old 05-18-2004, 06:01 PM
Street Ghost's Avatar
Default Re: (onesikviet)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by onesikviet &raquo;</TD></TR><TR><TD CLASS="quote">well, im going to get it smogged sometime later this week, which is the whole reason why its back to stock. you guys think this will be a problem? if he(smog tech) see's that theres a plug not connected to anything. thats all im worried about. TIA</TD></TR></TABLE>
Just hide the plug if you`re that worried.
Old 05-18-2004, 10:33 PM
onesikviet's Avatar
Default Re: (JDM Ninja)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM Ninja &raquo;</TD></TR><TR><TD CLASS="quote">
Just hide the plug if you`re that worried.</TD></TR></TABLE>
lol ill give that a try..thanks!
Old 05-18-2004, 10:46 PM
bretx0r's Avatar
throwing a code? no? dont worry about it.
Old 05-19-2004, 03:32 AM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by onesikviet &raquo;</TD></TR><TR><TD CLASS="quote">dunno where this one goes? green/black </TD></TR></TABLE>
It goes to the power steering presure switch. It should be on the p/s hose below the intake manifold.
Old 05-19-2004, 04:41 AM
articbluedc5's Avatar
Default Re: last plug...(pic) (Chiovnidca)
I have 2 of the same things left over. One goes to the IAT sensor on the Intake mani. One was on some black peice I am guessing the evap purge and I don't know where the other goes.
Old 05-19-2004, 05:23 AM
Louie_EM1
Guest
Posts: n/a
Default Re: last plug...(pic) (Two_K Si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Two_K Si &raquo;</TD></TR><TR><TD CLASS="quote">There is also a plug that plugs into the ps pressure switch on the steering rack. Maybe check it since you said your car is running fine.</TD></TR></TABLE>
Yeah do you have power steering if not, then that's possibly it I'll take a look at my car later today and check.
Old 05-19-2004, 05:37 AM
EVILhatch's Avatar
its your secondary o2 sensor plug,you wont be needing it to plug into anything since you allready have one in the header.
Old 05-19-2004, 08:36 AM
built562's Avatar
Default Re: (EVILhatch)
the person who said evap purge solenoid was right, here is my thread on it
https://honda-tech.com/zerothread?id=859796
you might need it because now you have an empty spot on your chracol canister where it would hook to the solenoid you are missing, but since you are using a jdm computer it does not look for the evap purge solenoid hence no check engine light.
if you were to plug in a usdm ecu you would get a check engine light
Old 05-19-2004, 09:07 AM
Slopoke's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EVILhatch &raquo;</TD></TR><TR><TD CLASS="quote">its your secondary o2 sensor plug,you wont be needing it to plug into anything since you allready have one in the header.</TD></TR></TABLE>
o2 sensors have 4 wires, not 2.
Looks like evap purge solenoid to me, too.
Old 05-19-2004, 11:55 AM
ricebox's Avatar
Default Re: (Slopoke)
power steering
Old 05-19-2004, 12:19 PM
Chiovnidca's Avatar
Default Re: (akumaracer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by akumaracer &raquo;</TD></TR><TR><TD CLASS="quote">the person who said evap purge solenoid was right, here is my thread on it
I don't think so, the wire colors are wrong. The purge control solenoid wires should be blk/yel and red/yel. He said the wires were grn and blk. P/S switch is the only one with those colors.
Old 05-19-2004, 03:53 PM
onesikviet's Avatar
Default Re: (Chiovnidca)
update:
it was my PS! THANKS to everyone that helped.
Old 05-19-2004, 04:07 PM
EE_Chris's Avatar
n/m
redskittle
12-23-2005 01:36 PM
tony n.
06-29-2005 09:28 PM
Treblarefils
06-07-2005 11:54 PM
Unjockable
16
01-01-2004 05:11 PM
Quick Reply: last plug...(pic)
