KYB AGX...how the heck ????
ok...i just received my shipment of KYB AGX's for my 93 civic hatch...and i was looking at them and it seems like its hard to put on....its about 3 in the morning, thats why im not out trying them on...does anyone have AGX's ??? can you post pictures and guide me through the installing process, PLEASE !!!!...ANY help would be appreciated. THANKS !
Re: KYB AGX...how the heck ???? (nocturnal EG)
first try searching if that doesnt work it is in the haynes if that doesn't work here goes
1 put car in the air
2 take off tire
3 remove lca to spindle castle nut 17mm
4 remove damper fork to lca bolt 17mm
5 remove damper fork to damper pinching bolt 14mm
6 swivel both sides of fork until it slides down
7 pop ball joint under spindel off may need pickel fork
8 remove sway bar nut(it doesnt have to come out of the car just disconnect
9 remove anything else holding you up(traction bars etc
10 move the damper fork out of the car
11 remove three nuts in engine bay on the shock tower 14mm
12 remove damper
13 get spring compressor 15 bucks at pep boy etc
14 compress spring remove top nut
15 follow kybs instructions on the perches etc
16 follow these directions in reverse
Did you get springs?
ive never worked with rear drums i can only asume that its the same
2 take off tire
12 remove damper
Re: KYB AGX...how the heck ???? (integra6650)
thanks for the help..i have no idea what you are talking about..but i think i know how to do it...i hope...=] thanks again.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nocturnal EG »</TD></TR><TR><TD CLASS="quote">thanks for the help..i have no idea what you are talking about..but i think i know how to do it...i hope...=] thanks again.</TD></TR></TABLE>
What the...? I don't think you should be buying parts for you car.
https://honda-tech.com/zerothread?id=858113
if you have no idea waht youre doing have a friend that does help you or pay someone...dont wanna **** up anything that has to do with suspension
Re: KYB AGX...how the heck ???? (Art In Motion)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Pat McGroin »</TD></TR><TR><TD CLASS="quote">
I second the motion
I second the motion
Solbros Owns Me
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integra6650 »</TD></TR><TR><TD CLASS="quote">first try searching if that doesnt work it is in the haynes if that doesn't work here goes
13 remove lca to spindle castle nut 17mm
11 remove three9TWOnuts in engine bay on the shock tower 14mm
none of those steps are needed. JUst unbolt the fork from the damper and the LCA and the brake line brackets and the upper top mount bolts
Re: KYB AGX...how the heck ???? (Emerika)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Emerika »</TD></TR><TR><TD CLASS="quote">
none of those steps are needed. JUst unbolt the fork from the damper and the LCA and the brake line brackets and the upper top mount bolts</TD></TR></TABLE>
werd. just get a helms manual. it has step-by-step illustrated instructions. it doesnt get any easier. if you dont have the $$, get a haynes at any autoparts store. they're pleanty descriptive and they have pictooors to look at.
Vice President/CEO
trust me, its really not as hard as it looks... i did my suspension lastnight. Tein/AGX on my 92 Hatch.
everything went great, nothing but alot of elbow grease and Pepsi'
Before Picture of Rear:
After:
After:
Vice President/CEO
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integra6650 »</TD></TR><TR><TD CLASS="quote">i like the color combo it makes me feel like christmas and is much nicer than the yellow red i got. How do they feel?</TD></TR></TABLE>
That feel GREAT! I love them... i am 100% happy with the combo. I took my roomate out for a spin in them after i installed, he was really impressed. He is a Tokico driver w/ nuespeed springs (sp?)
over all... A+ from me'
SoullessJapaneseMachine
06-19-2008 09:56 AM
Dai_Ca_Vietnam_H22a4
02-09-2006 02:09 PM
