Kosei K1's w/ Kumho 712 for my CX hatch
Old 06-21-2001, 02:40 AM
Downey's Avatar
Default Kosei K1's w/ Kumho 712 for my CX hatch
My dad just came home and asked me what i wanted for my birthday. I said i cant stand the 13' steel rims i have on my CX so can i get some wheels. So ive decided to get white 15x7 Kosei K1's with 205/50-15 Kumho Ecsta Supra 712 tires. What offset wheels should i get? Will i get any rubbing with the 205 tires?
Old 06-21-2001, 06:11 AM
eg6ajk's Avatar
Default Re: Kosei K1's w/ Kumho 712 for my CX hatch (Downeybear11)
40-43 is good.....but why 205, go with 195, cheaper, lighter and less problems with rubbing...
Old 06-21-2001, 06:16 AM
CivicSiRacer's Avatar
I've heard rubbing issues with the 43 offset 15x7" Kosei K1. I have the Kosei K1 in 16x7.5" with 43mm offset and it rubbed on my UCA (upper control arm) so I filed it down about 1-2mm and now it's fine. I'm also running 215/40x16" Kumho 712s for autocross on those wheels.
I would get the 38mm offset for the 15x7". You just cannot drop your car more than 1.5".
Old 06-21-2001, 06:17 AM
Default Re: Kosei K1's w/ Kumho 712 for my CX hatch (eg6ajk)
205/50x15" will give better cornering traction. Plus 205s are perfect on a 7" wide wheel. Why do you think people are running 205/40x17 & 205/45x16" You shouldn't rub with the right set up.
Old 06-21-2001, 11:10 PM
New User
Scorpaznatica's Avatar
45mm offset would be your best bet....they dont have 43mm offset for the 15" k1.
You'll need to file down the upper control arm a bit, because Honda failed to do so at the factory. They shave the Integras upper control arm
Old 06-21-2001, 11:12 PM
Downey's Avatar
Default Re: Kosei K1's w/ Kumho 712 for my CX hatch (EKnine)
43mm or 45mm offset?
Old 06-21-2001, 11:24 PM
New User
jdmegcivic's Avatar
:eek:
Old 06-21-2001, 11:35 PM
Downey's Avatar
Default Re: Kosei K1's w/ Kumho 712 for my CX hatch (jdmegcivic)
:eek: ???
Old 06-22-2001, 11:50 AM
New User
cheezemaster's Avatar
I run 205 on 38mm 15x7 k1's with pro-kit. No rubbing when i had the sohc (i rub occasionally up front with the dohc).
B16CRXT
05-25-2005 03:12 PM
CRX Toad
05-13-2005 12:30 AM
^jefs0ng
01-01-2004 07:17 PM
CivicSiRacer
10
02-28-2003 05:21 AM
MRDC2
02-21-2003 05:33 PM
Quick Reply: Kosei K1's w/ Kumho 712 for my CX hatch
