Knocking noise - oil pump?
First time on this site and hope someone can help. Bought a 1994 Civic from a friend at work. Said he was driving down road and oil light came on and he heard noises so he put in oil - and kept putting it in waiting for the oil light to go off. It never did so he towed in home and I bought it. First off when I started it the oil light was not on and I could tell it had WAY too much oil in it. So I drained out all the oil and put in the right amount. No metal in pain or anything. Motor starts up no lights on dash but there is a definite knocking type sound and oil light flashes off and on intermittently. Could this just be the oil pump being loose or something silly like that - It doesn't really sound like rod. Maybe something with the timing belt affecting the oil pump? Any thoughts would be appreciated.
Also I was trying to get to the timing chain, etc. to get to the oil pump and can't get the stupid harmonic balancer bolt to break lose either - any suggestions on how to break that pupply loose?
Re: Knocking noise - oil pump? (Tonya1994)
it could be a bent valve if the sound location seems distinct
else if it's a general noise from your valve train, it could need lash adjust
Re: Knocking noise - oil pump? (dafuzzbudd)
It's just a dull knock - not really a metal on metal clatter. It starts right up - just has that noise - almost like the timing belt is hitting something or not making good connection with the oil pump gear and causing the oil light to go off an on. If I could get the balancer bolt out I could probably figure something out. Noise is on very side/front of motor - driver's side
