Go Back  Honda-Tech - Honda Forum Discussion > Honda and Acura Model-Specific Technical Forums > Honda Civic / Del Sol (1992 - 2000)
Reload this Page >
Knock Sensor...Tried rewiring and changing knock sensor so far...Help Please
Old 07-31-2004, 11:44 PM
SivikHatch's Avatar
Default Knock Sensor...Tried rewiring and changing knock sensor so far...Help Please
I have a 96 civic hatch with a built OBD 2 b18c1 motor running off a P73 ecu. The code im getting right now is 23, which is the knock sensor. The cel doesn't come on right away, it comes on after i put a load on it. So I tried changing the knock sensor(...its on tight) and resetting the ECU by pulling radio backup fuse. CEL is gone. So i gave it a test run, and whadda ya know...It comes on again. So then i tried changing the knock sensor wire with insulated wires soldered well together and resetted the ECU again. Again, i went for a test spin and whadda ya know...it comes on again...SO WTF IS GOING ON? I'm about to try another ECU, but before I buy another one I wanted to see what you guys think... Any info would be nice...unless my motor really is knocking(I don't hear anything), it wouldn't be so nice... without vtec life isn't worth living...
SivikHatch is offline
Old 08-01-2004, 07:39 AM
SivikHatch's Avatar
Default Re: Knock Sensor...Tried rewiring and changing knock sensor so far...Help Please (SivikHatch)
morning bump before I go outside to try changing the 1 year old gas with premium gas from texaco...
Old 08-01-2004, 08:29 AM
RTFM
1 year old gas for your civic engine probably isnt too great for a b18c....
v4lu3s is offline
Old 08-01-2004, 09:56 AM
SivikHatch's Avatar
Default Re: (v4lu3s)
This what I did so far... changed the gas to octane 93... and redid timing belt at TDC... resetted ECU... I cranked the car and let it run until radiator fan came on... then i reved it up to like 3400 rpm and the CEL came on again... F*ck... I guess ill buy another ecu...
Old 08-01-2004, 10:04 AM
hatchling37's Avatar
Default Re: (SivikHatch)
Do you have a friend that you could swap ECU's with? Just to plug his in to see? It might confirm your assumption...
hatchling37 is offline
Old 08-01-2004, 10:41 AM
SivikHatch's Avatar
Default Re: (hatchling37)
I'm going to bring my ECU to someone else to test it on their car and see how it goes... would that be just as fine as having them letting me borrow theirs to test on my car? I don't want to risk driving my car over there with the CEL on. I'll have to travel out of town to get it tested... no one in town drives a GS-R... I live in the middle of no where...
Old 08-01-2004, 11:15 AM
SC0TT's Avatar
Might want to try splicing a ground into the KS wire. Got rid of my CEL.
SC0TT is offline
Old 08-01-2004, 08:53 PM
SivikHatch's Avatar
Default Re: (SC0TT)
I heard grounding it out isn't safe... my motor is a built motor should i risk it by grounding it?
Old 08-01-2004, 09:00 PM
Civiclx's Avatar
Default Re: (SC0TT)
you need to use oem knock sensor wiring (like coax) needs to be grounded on both the ecu and ks side, i did it like this and no cel, good luck, i was selling some but ran out
Civiclx is offline
Old 08-10-2004, 03:14 AM
sQwiReL bOi
Guest
Posts: n/a
i have the same problem rite now... i burrowed and tried out 3 different ecus on my 97 gsr. 1st stock... knock after i put a lil load on it. 2nd stock p28 wit jumper.... same. 3rd chipped p28... same. its weird cuz i thought p28 dont have knock... but i still get the damn 23 code.
Old 08-10-2004, 04:01 AM
2lua's Avatar
are you sure that you read the code right? like you said p28 doesn't have knock sensor. as for routing the knock sensor wire. it needed to be away from anything that will cause electrical noises, like alternator, starter...
2lua is offline
Old 08-10-2004, 04:25 AM
EE_Chris's Avatar
Default Re: (Civiclx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Civiclx &raquo;</TD></TR><TR><TD CLASS="quote">you need to use oem knock sensor wiring (like coax) needs to be grounded on both the ecu and ks side, i did it like this and no cel, good luck, i was selling some but ran out</TD></TR></TABLE>
Please be aware that OEM Honda only grounds the KS shield in ONE spot. The way you have it hooked it up could potentially lead to ground loops and noise.
On a 99 Ex/Si, the KS shield is grounded to G101.
EE_Chris is offline
Old 08-11-2004, 01:41 PM
SivikHatch's Avatar
Default Re: (2lua)
2LUA, yes i read the code right... blink, blink, fast blink, fast blink, & fast blink... code 23 correct?
Old 08-11-2004, 02:06 PM
SivikHatch's Avatar
Well got another ECU today and gave it a test. Knock sensor code is still there. What else is there to fix the problem?
I can rev up to 8000 easily now. thats the only thing i noticed different.
Old 08-11-2004, 07:30 PM
SivikHatch's Avatar
bump
avasaka
05-21-2015 02:21 AM
93EJ2
21
02-27-2009 01:48 PM
sheBangZ
12-30-2005 12:19 AM
Old_Nocturnal
08-12-2003 12:16 PM
bigTom
Kill Stories
12
07-18-2001 06:58 AM
Quick Reply: Knock Sensor...Tried rewiring and changing knock sensor so far...Help Please
  • Ask a Question
Question Title:
Description:
