knock sensor
knock sensor
please go to this link and help me out...no flaming please!!
https://honda-tech.com/zerothread?id=331675
Re: knock sensor (pennies_hatchie)
yep, I don't have a knock sensor.....the engine light is on in my B16A, I will get one when I have the money to put a new one in...but it will not hurt engine. Just make sure you don't have "knocking in engine" otherwise could hurt the engine.
Re: knock sensor (Hooch at 8400-RPM)
it doesnt sound like there's any pings or knocking. im planning to do a lot of highway usage so i just wanted to be on the safe side. thanks.
oh and does the d16z6 come with a knock sensor becuase i have a sensor on my wire harness from the d16z6.
Re: knock sensor (djay86)
you might be able to get away with using high octane fuel
Re: knock sensor (Blk93CivicSi)
Its not hard to wire. if that is your problem. just run a wire from D3 on your ecu. you should be running a p30 ecu.
ttt, i need answers....
1. does d16z6 wire harness have a wire on it already for knock sensor
2. if it doesnt, then what type of wire do i need (volts, etc)
3. where to get wire so i can hook it up manually
The d16z6 does not have a knock sensor on the harness. I cut mine off of my JDM harness, I will see if that harness has another plug that is the same on it or not. If it doesn't I'll take a pic of it tonight and send it to you so you know what to look for. You can get just about any kind of shielded wire to make it work. Just make sure it goes to plug D3 on your ECU. I am not sure what gauge wire I am using but I will let you know that as well after I get home and look at it tonight. Hopefully i will have an extra one on my JDM wire harness though. I'll keep ya posted.
BTW Are you running a P30 ECU?
D
D
hey thanks Blk93Civicsi, thats all the answers i need. i still have the JDM wire harness that came with the swap and im probably going to cut that and connect it with a gauge wire. but im now wandering what that extra plug on my si harness is for because i believe its brown, has red and green wire going to the plug? not positive on that though. and yes, i am running a p30. thanks everyone!!
BILLisCHILL
05-08-2008 06:40 PM
