Is this a knock? :(
Is this a knock? :(
[url=http://youtube.com/watch?v=8Q6c3hl5FXM[/url]
i really hope not
4k on the bottom end
just did an oil change i think its been doing this for at least 3k miles now
i was told its valve tick but yeah what do you guys think?
EDIT:
poor man R ctr pistons b16 head oem headgasket
rocket valvesprings and titanium retainers with skunk2 stg2 nono pro cams
intake adjusted to .007 and exhaust .008
Modified by preludedriva at 1:50 PM 10/18/2007
Modified by preludedriva at 10:24 AM 12/31/2007
i really hope not
EDIT:
Re: Is this a knock? :( (forcefedferio)
Hard to tell off your video, sounds almost like pinging even. Videos dont help unless if its really bad. If you been on this for 3k then its not rod probably valves. Try a valve adjustment. Is the motor tuned?
Re: Is this a knock? :( (Luserkid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid »</TD></TR><TR><TD CLASS="quote">Hard to tell off your video, sounds almost like pinging even. Videos dont help unless if its really bad. If you been on this for 3k then its not rod probably valves. Try a valve adjustment. Is the motor tuned? </TD></TR></TABLE>
i did a valve adjustment 007 on intake and 008 on exhaust thats what the spec sheet is for the stg2 skunk2 cams
and yes its tuned on crome pro
you dont hear the noise til i rev it past 1k at idle you dont hear it at all
Re: Is this a knock? :( (preludedriva)
Sounds just like when my buddies MR2 let go of a rod bearing, almost identical to the sound of the 200k mile D16 rod knock his brother had too. Sucks, hopefully it's not that but it sure sounds like it.
-Froth
-Froth
Re: (lilracerhb)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lilracerhb »</TD></TR><TR><TD CLASS="quote">Who put your engine together </TD></TR></TABLE>
i did used acl bearings torqued down to spec
Re: (preludedriva)
I cant really tell from the video...but try to pinpoint where the noise is coming from. why dont you drain the oil and check to sparkly flakes or drop the pan and take a look inside
Re: (preludedriva)
i got rocketmotorsport springs retainers oem valves and skunk2stg 2 cams with 3 angle valve grind if that makes a difference?
Re: (preludedriva)
k i just dropped the pan
no shavings whats so ever at all
BDC the rods and i pushed up on the bottom caps and i dont get any movements at all
erm i beleive its in the head maybe a loose rocker or something? lma? valve adjustment has been done
Modified by preludedriva at 1:52 PM 10/18/2007
Re: (preludedriva)
could it be wristpins? when i bought my ctr pistons they were already inside the pistons and then i went to the machine shop and had them mounted on the rods
Re: (preludedriva)
my buddy had a 2.0 itr with 12.5:1 pistons and pro1s...honestly. i dont think thats rod knock. his engine had the proper valve lash and everything. ticked EXACTLY like that. and he had a WS2 exhaust so when he was really beating the **** out of it you could hear it plain as day. i highly doubt its a rod knock its probably valves more than anything
Re: (AdamB18C1EK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AdamB18C1EK »</TD></TR><TR><TD CLASS="quote">my buddy had a 2.0 itr with 12.5:1 pistons and pro1s...honestly. i dont think thats rod knock. his engine had the proper valve lash and everything. ticked EXACTLY like that. and he had a WS2 exhaust so when he was really beating the **** out of it you could hear it plain as day. i highly doubt its a rod knock its probably valves more than anything </TD></TR></TABLE>
i hope you are right lol
yeah my valves are adjusted correctly i did em twice
are we on the same page? the ticking is normal i was talking about the thumping noise when i give it some throttle
Re: (pdiggitydogg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pdiggitydogg »</TD></TR><TR><TD CLASS="quote">I dont think its rod knock either.
What is your cylinder bore (exactly)?
81mm
if theres no shavings or play in the rod caps then it wouldnt be rods knocking would it ?
81mm
we took a scope to the entire motor each cylinder on the block and even the head
the sound seems to be coming from the intake side on clyinder one
we also pulled 1 plug at a time to see if the sound got quieter and it sounded the same taking 1 out each time
Re: (Sloshy)
Bottom end noises tend to be dull and clunky sounding, like the sound represented in the video. Head noises are sharp and high pitched, just like a tap. The area to blame will have a sound proportional to the parts density, and ability to shed that sound. Keep this in mind, heavy parts clunk when you drop them, and small parts make a higher pitch tapping sound. This applies in an engine as well, and is a very good way to diagnose noise.
The valvetrain is clearly audible, and I will dismiss that as the origin based on what I've heard.
Disable your fuel system and crank the engine and see if the pitch and frequency change.
If the knock doubles up, the wrist pin or rod bearings are to blame. If you suspect a cylinder, remove the plugs in question to remove all stress from the components. This way the rod will have no force pressing down on it, exposing a bad clearance on the upstroke, and down, which should reveal a double knock if this is the case.
If you are questioning any part of your engine, please make it known, clearances and all. It all helps.
Re: (slowcivic2k)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slowcivic2k »</TD></TR><TR><TD CLASS="quote">Bottom end noises tend to be dull and clunky sounding, like the sound represented in the video. Head noises are sharp and high pitched, just like a tap. The area to blame will have a sound proportional to the parts density, and ability to shed that sound. Keep this in mind, heavy parts clunk when you drop them, and small parts make a higher pitch tapping sound. This applies in an engine as well, and is a very good way to diagnose noise.
If you are questioning any part of your engine, please make it known, clearances and all. It all helps.</TD></TR></TABLE>
i did take 1 plug at a time it sounded the exact same each time
its a new oil pump too as well
Re: (preludedriva)
Do not run the engine like that. Disable all fuel, and crank it over. If you suspect the number 1 hole, remove its plug, and listen for a double knock. The cranking of the engine will place the least load on that hole, permitting it to knock around more. Oil pressure will hide a knock, thats why its important the engine not run during the test.
Re: (slowcivic2k)
we also used a scope to try to determine where the noise was coming from
it was coming from the head clyinder 1 on the intake side we suspect a lma
