Kind you name this civic?
I tried to search but cant remember the name. It is the four door acura el i think. It looks like a 96-00 four civic but with a different front end and it has acura on the back 1.6something. Can somebody give me the actually name of this car and where i might be able to the conversion for a 99 civic. thanks
jus f0 dekarayshunZ
Re: (Evil_gambit33)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Evil_gambit33 »</TD></TR><TR><TD CLASS="quote">i believe vis sells a conversion. Somebody correct me if i am wrong</TD></TR></TABLE>NOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOO YOU LEFT THE CREW!!! yes vis sells a conversion
Re: (ciRcuitSi y0!)
so .. those are the what year EL ?
and can i buy a conversion in the states ??
and they are called domani ?
cmon people some more info on the car please..
Re: Kind you name this civic? (1fastgsrturbo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1fastgsrturbo »</TD></TR><TR><TD CLASS="quote">I tried to search but cant remember the name.</TD></TR></TABLE>
i think it's name is christopher! yes it is an acura el.
yeah i saw on in minnesota on the way to work in the begining fo the summer i was like "what kind of conversion did that fool do?" then i got to work and hopped on the internet and found out it was a canadian car. I wouldnt mind having on and slapping in a b18
Re: Kind you name this civic? (NINJASPY)
ya those are canadian cars, and from what I've heard also is that they are direct swaps, I would love to see one down here in the states.....
Re: (visionism0)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by visionism0 »</TD></TR><TR><TD CLASS="quote">so .. those are the what year EL ?</TD></TR></TABLE>
i think the first el is a 98, the 2nd el is a 97, and i'm not sure about the last el ...i do know it's not a 01-03 el though. supposidly, the grilles on the 97-98 els are different from the 99-00 els. the 01-03 els have a similar body to the 7th gen civic sedans.
no clue about the rest of your questions.
you may find more info about els at http://www.clubel.ca/
Re: (visionism0)
Stock specs: 1997-1999
Engineering
Engine Type: 1.6-litre, SOHC, VTEC
Horesepower, SAE net: 127 hp @ 6600 rpm
Torque, SAE net: 107 lbs.-ft (144 N.m) @ 5500 rpm
Redline: 6900 rpm
Bore & Stroke: 75 mm x 90 mm
Displacement: 1590 cc
Compression Ratio: 9.6:1
Fuel System: Multi-point Programmed Fuel Injection (PGM-FI)
Valvetrain: 4-valves-per-cylinder with VTEC
Manual Transmission: Standard 5-speed
Automatic Transmission: Available 4-speed electronic
Performance
Accelaration (0-100kmh) 8.7 sec.
Top Speed 195 Kmh
Cx 0.32
Body / Suspension / Chassis
Body Type: Unit Body
Suspension,
Front and Rear: Independent double-wishbone with coil springs and stabilizer bar
Shock Absorbers: Gas pressurized with Honda Progressive Valve (HPV)
Wheel (Size): 6.0JJ*15
Wheel (Type): 1.6EL Standard - Steel,
1.6EL Sport and Premium - Alloy
Tires: All-season, 195/55 R15 84V, Michelin XTG V4 (see the links section)
Braking System, Front: Power-assisted ventilited disc
Braking System, Rear: Power-assisted drum
Anti-Lock Bracking
System: 1.6EL Sport and Premium
Front Stabilizer Bar: 24 mm
Rear Stabilizer Bar: 13 mm
Capacities
Fuel Tank Capacity: 45 litres
Cargo Volume: 337 litres
Passenger Volume: 2543 litres
Fuel Economy
City/Highway: 1.6EL(all) 5-speed: 8.1/6.3 L/100km
City/Highway: 1.6EL(all) Automatic: 9.1/6.7 L/100km
Safety features
Driver's and front passenger's air bag Supplemental Restraint System (SRS)
8-km/h impact-absorbing body-coloured bumpers
Side impact door beams
Security System
Keyless enrty with panic feature and trunk release
Interior Dimensions
FRONT
Head Room: 1011 mm, 970 mm (Premium)
Leg Room: 1085 mm
Hip Room: 1270 mm
Shoulder Room: 1331 mm
REAR
Head Room: 955 mm, 920 mm (Premium)
Leg Room: 866 mm
Hip Room: 1252 mm
Shoulder Room: 1316 mm
Exterior Dimensions
Wheelbase: 2620 mm
Track, front: 1475 mm
Track, rear: 1475 mm
Length: 4478 mm
Width: 1705 mm
Height: 1395 mm
Min. Ground Clearance: 115 mm
Curb Weight
1.6EL Standard: 5 M/T 1124 kg, 4 A/T 1149 kg
1.6EL Sport: 5 M/T 1144 kg, 4 A/T 1169 kg
1.6EL Premium: 5 M/T 1162 kg, 4 A/T 1187 kg
-VTEC kicks in at 5200
-Yes they are called domani in japan, in canada its just called 1.6 EL (97-99) but for 2000 and up, its called 1.7 EL, different everything...(pretty much looks like the new civic sedans)
hope this helps ?
Engineering
Redline: 6900 rpm
Performance
Top Speed 195 Kmh
Cx 0.32
Suspension,
Anti-Lock Bracking
Capacities
Fuel Economy
Safety features
Security System
Interior Dimensions
FRONT
Leg Room: 1085 mm
Hip Room: 1270 mm
REAR
Leg Room: 866 mm
Hip Room: 1252 mm
Exterior Dimensions
Wheelbase: 2620 mm
Length: 4478 mm
Width: 1705 mm
Height: 1395 mm
Curb Weight
hope this helps ?
Re: (drunkn_tyger)
Just find a Canadian wrecker with one hit in the rear. Parts direct from Acura will make you go broke. Tons of wreckers up here in the Vancouver area.
Re: (Trunks714)
my friend got his from canada... i seen both cars in person here in sac.. the 1.6EL and the 1.7EL i was suprised to see them here but they are both very nice
