Keep throwing codes 1-7 and 4-3??
I keep throwing the speed sensor and fuel supply codes every once in a while and am wondering if this is a common problem with 95 civics? I get the 4-3 even with a full tank of gas and I just ran some seafoam through the brake booster line and put the rest in the gas tank to try to clean things out. Any suggestions?
Re: Keep throwing codes 1-7 and 4-3?? (SR20 Inside)
If the fuel presure is in spec and there are no large vacuum leaks, code 43 is usually caused by a bad o2 sensor.
Re: (SR20 Inside)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SR20 Inside »</TD></TR><TR><TD CLASS="quote">what about vss speed sensor? is that something to do with vtec solenoid switch ?</TD></TR></TABLE>
Nope, vehicle speed sensor/circuit.
